Re: snd_pvm_open_preferred - preferences file.
07/28/2011 5:35 PM
post87662
It would look something like this:
> # cat /etc/system/config/audio/preferences
> pcmPreferredp "Audiopci 1371" 1
Preferred device name (you can set preferred playback or capture
device), the device name (if you have the audio driver source you can
lookup the function call to ado_card_set_shortname(); if you don't, you
should be able to get this by calling snd_pcm_info() and looking at
snd_pcm_info_t.name (this is the longname, not the shortname, but should
still work). The last number is the device number for that card.
With the above config my /dev/snd/ looks like this:
-rw-rw-rw- 1 root root 0 Jul 28 17:31 pcmC0D0p
-rw-rw-rw- 1 root root 0 Jul 28 17:31 pcmC0D1p
lrw-rw-rw- 1 root root 0 Jul 28 17:31 pcmPreferredp
-> pcmC0D1p
If I swap the last 1 for 0, pcmPreferredp points to pcmC0D0p.
Ryan J. Allen
QNX Software Systems
