Seeking advice for Aviage to support low power mode
07/27/2010 10:14 PM
post60825
There is a customer requirement that the system needs to go to low power mode within 5ms, and before it enters low power
mode, the io-usb instance needs to be slain so the USB transceiver can be shut off.
Because io-usb is the crucial instance for Aviage suite while the connected iPod or usb key is playing, we can't just
slay io-usb without doing some proper handlings for Aviage beforehand. E.g., we might need to use mme_stop() to stop any
playback first, then do some handling for Aviage like slaying all Aviage instances including the io-usb in worst case,
then the system can go to low power mode. However, it seems it is hard to get all these things done within 5ms.
Now just seeking some advice of how to handle this case for Aviage to let it be able to enter low power mode within 5ms,
and to ensure it is recoverable
after back from low power mode, much thanks.
(Our testing hardware is a 400MHz freescale iMX31 platform and the Aviage Multimedia Suite is version 1.2)
Chris
RE: Seeking advice for Aviage to support low power mode
07/27/2010 10:51 PM
post60827
I think there could be two approaches:
1. you kill io-usb and drivers that depend on it (devb-umass, io-fs-media -dipod, etc.). These mediastores will go
away, and the MME will eject them. Upon restarting the driver the MME will re-insert the mediastores and you must
recover your playback state as desired.
2. slay mme-generic. No other process should write to the database, and the database is the only real persistent
location between executions. If mme-generic dies it won't log funny mediastore ejections, etc. And it is meant to try
to recover from "sudden deaths" in case of unexpected crashes. Upon restarting mme-generic it will re-discover
available mediastores.
Playback and sync will stop automatically in either case, because the MME or the mediastore will go away. If you're
concerned about your application getting undesired events in the case of suggestion 1. then killing the MME may be
better; if you're concerned about the database being consistent then suggestion 1. may technically be safer, but you
will end up with errors and ejections of each mediastore.
Ryan J. Allen
QNX Software Systems
Re: RE: Seeking advice for Aviage to support low power mode
07/28/2010 10:21 PM
post60994
Much thanks your advice, Ryan.
Just found that the whole process of slaying the necessary instances like mme-generic, iPod driver or umass driver, enum
-device and io-usb takes at least hundreds of ms to finish, it is still a bit hard to satisfy the 5ms requirement.
Chris
07/29/2010 2:09 PM
post61091
Have you just tried to time how long slaying io-usb only takes?
07/29/2010 6:58 PM
post61116
Hi Gilles,
So far I have found that it took at least 50ms to slay the io-usb instance from a system call, sometimes 70ms or longer.
Chris
Re: Seeking advice for Aviage to support low power mode
07/29/2010 9:14 PM
post61124
5 msec isn't much time. One thing you might also consider is the priority at
which you are terminating io-usb at. You might be terminating it at priority
10 (often a typical process priority) while other thing might be running at
higher priority on the system.
Also, how are you testing this? Using something like "time slay io-usb" in a
shell is bad. It has to spawn a time process, which spawns slay, etc.. all
of which might take over 5 msec if it is pulling these binaries from a flash
file system.
Gilles
07/29/2010 9:56 PM
post61127
Yes, I have thought about the priority problem and tried increasing the calling thread's priority from 10 to 20, it just
has a slight improvement but far from reaching the goal of 5ms.
> file system.
> Gilles
Actually I just use a timer to trace how long the system("slay io-usb") call takes, it is not the exact time it used for
slaying the io-usb. However, I need to use this mechanism to slay other instances which depended on io-usb as well, so
the whole slaying process for all necessary instances takes much longer than 5ms.
Chris
07/29/2010 10:08 PM
post61128
> takes, it is not the exact time it used for slaying the io-usb. However, I
> well, so the whole slaying process for all necessary instances takes much
> longer than 5ms.
OK, well if you had tracked the pid ahead of time you could call kill(). It
would be much faster than system("slay io-usb"). I was just thinking you
might be able to get away with just slaying io-usb and then slaying they
other processes once you power down the USB power.
Gilles
07/29/2010 10:17 PM
post61129
You can also skip any chance of io-usb (or whatever process you kill) cleaning up by using SIGKILL rather than SIGTERM.
The safety of this depends on what state you expect the system to be in after the low power mode (and whether the newly
spawned instance of io-usb, or whatever process, can recover the hardware without cleanup).
In any case, if I'm not mistaken, the OS will spawn a little cleanup thread in your dead process to free up system
resources that may otherwise be left; I don't know how long this will take but it may be a factor in what is taking so
long. It might be an idea to take a kernel trace of your current method to get an idea of where the longest times are
spent (ie, is it in the system() call, io-usb "cleaning up" by catching the SIGTERM, the OS cleanup thread, etc.).
And if the conversation has really shifted from "what is safe from an MME perspective" to "how can I kill something
quickly" then I would also suggest posting the question in the OS forum. There are a lot of bright people who monitor
that forum that don't monitor the MME forum.
<http://community.qnx.com/sf/discussion/do/listTopics/projects.core_os/discussion.newcode>
Ryan J. Allen
07/29/2010 10:35 PM
post61131
> up by using SIGKILL rather than SIGTERM. The safety of this depends on what
> newly spawned instance of io-usb, or whatever process, can recover the
> your dead process to free up system resources that may otherwise be left; I
> get an idea of where the longest times are spent (ie, is it in the system()
> perspective" to "how can I kill something quickly" then I would also suggest
> monitor that forum that don't monitor the MME forum.
> Ryan J. Allen
Thanks your info and suggestion, Ryan.
Actually I am not keen to slay instances in order to go to low power mode unless have to do so. Now just consider
finding a way to 'pause' io-usb rather than slaying it. And just wonder whether it will cause any issues to Aviage if
the io-usb is suspended while playing a track or the mme is enumerating a usb device, thanks.
Chris
07/29/2010 10:25 PM
post61130
Hi Gilles,
Yes, you are right. I have also tried using kill() as well, it is faster but still far from the target time limit. Now
we are considering using other methods, e.g., find a way to 'pause' the io-usb but not slay it.
Just wonder, if the io-usb is really can be 'paused' by stopping the associated interrupts, suspending the threads etc,
will it cause any issues to Aviage, or whether Aviage is recoverable without slaying any instances, thanks.
Chris
07/29/2010 10:38 PM
post61133
> still far from the target time limit. Now we are considering using other
> associated interrupts, suspending the threads etc, will it cause any issues to
> thanks.
I suspect in the OS forum you might get tips on how to quickly kill io-usb,
as Ryan suggested.
Pausing USB might be odd in some Multimedia scenarios. For example, if the
MME was reading from a usb stick, would it just block until you unpaused
io-usb? If MME/io-media threads start blocking, then when you call into the
MME your threads will start blocked, etc... it will creep up until many
parts of the system might be blocked.
USB calls failing might be easier to handle. You could/would get MME play
errors, or sync abort errors, but I suspect that the MME would recover when
the usb stack comes back up.
Gilles
07/30/2010 12:28 AM
post61143
Got it and thanks for your info, Gilles.
Chris
