Re: ftype in nowplaying and library table
03/17/2010 8:40 AM
post49730
On Wed, 17 Mar 2010, Mate Szarvas wrote:
>Subject: ftype in nowplaying and library table
> The documentation of the "ftype" column of the "nowplaying" table is
> referring to the "library" table for details, therefore I'd expect that these
> two columns in the two tables have identical meanings and would have
> identical values when the "fid" in the two tables is identical.
> But this does not seems to be the case.
> In the following example we are playing back music via A2DP (Bluetooth) from
> an iPod touch 2G. The value of "ftype" is 1 in the "nowplaying" table and 5
> in the relevant row (fid=4) of the "library" table. What is the reason for
> the different values and what is the meaning of the "ftype" column in the two
> tables?
> mme-generic and io-media are 1.2+PSP; the io-fs-media driver for A2DP is
> customer implemented.
> # qdbc -d mme "select * from nowplaying;"
> Rows: 1 Cols: 26
> Names: +ccid+playing+fid+msid+ftype+year+bitrate+samplerate+num_channels+size+discnum+tracknum+rating+copied_fid+
filename+artist+title+album+genre+composer+conductor+soloist+ensemble+opus+category+description+
> 00000: |1|0|4|4|1|0|0|0|0|0|0|1234|0|0||Bluetooth: no artist||Bluetooth: no album|Bluetooth: no genre||||||Unknown
Category||
> # qdbc -d mme "select * from library where fid=4;"
> Rows: 1 Cols: 40
> Names: +fid+msid+folderid+ftype+accurate+last_sync+seen+artist_id+album_id+genre_id+year+size+category_id+composer_id
+discnum+titlenum+tracknum+rating+date_added+date_modified+bitrate+audio_index+format+num_channels+language_id+
samplerate+conductor_id+soloist_id+ensemble_id+opus_id+protected+last_played+fullplay_count+duration+copied_fid+playable
+permanent+description+title+filename+
> 00000: |4|4|4|5|1|0|1|1|1|1|0|0|1|1|0|0|0|0|0|0|0|0|0|0|1|0|1|1|1|1|0|45096954903|0|0|0|1|0||Bluetooth||
> # qdbc -d mme "select * from mediastores where msid=4;"
> Rows: 1 Cols: 19
> Names: +msid+slotid+available+storage_type+trksessionid+lastseen+capabilities+active+location+syncflags+concurrency+
supported+last_sync+metadatapluginid+mssname+name+identifier+driver_identifier+mountpath+
> 00000: |4|5|1|12|0|42956957043|2147512279|1||0|1|1|0|0|mediafs2wire|test iPod|SERIAL_123|[NULL]|/fs/avrcp0|
> # qdbc -d mme "select * from trksessionview;"
> Rows: 1 Cols: 4
> Names: +sequentialid+fid+trksessionid+randomid+
> 00000: |6|4|1|0|
Its similar when you're playing from an internet audio stream:
# qdbc -dmme "select * from library where msid=2"
Rows: 1 Cols: 40
Names: +fid+msid+folderid+ftype+accurate+last_sync+seen+artist_id+album_id+genre_id+year+size+category_id+composer_id+
discnum+titlenum+t
racknum+rating+date_added+date_modified+bitrate+audio_index+format+num_channels+language_id+samplerate+conductor_id+
d+opus_id+protected+last_played+fullplay_count+duration+copied_fid+playable+permanent+description+title+filename+
00000: |2|2|2|5|1|0|1|1|1|1|0|0|1|1|0|0|0|0|0|0|0|0|0|0|1|0|1|1|1|1|0|1268815030990739074|0|0|0|1|0||INTERNET||
# qdbc -dmme "select * from mediastores where msid=2"
Rows: 1 Cols: 19
00000: |2|13|1|22|0|1268753084345026199|2147492096|1||15|1|1|1268753084349025587|0|internet|Internet|/dev/socket|[NULL]
|/dev/socket|
# qdbc -dmme "select fid,msid,ftype from nowplaying"
Rows: 1 Cols: 3
Names: +fid+msid+ftype+
00000: |2|2|1|
The entry in the library is a device type which would indicate that it is not a
searchable item. We will only attach and have limited control of it. When we
play from it, we're reporting the ftype of the stream that we're playing
(probably based on...
