Howto instruct the flash player to target more than one display at a time
03/15/2010 1:47 PM
post49502
Hello all:
I have recently discovered that support for multiple displays was recently added to the flash player and to enable
support, one needs to use the hmip-compmgr.so extension in the flash.conf as follows:
[code]
extension {
dll = hmip-compmgr.so
config {
display = 1
[/code]
Assuming a minimum of two device entries in display.conf, and io-display started with both devices specified at the
command line what is the correct way to instruct the flash player to target both displays simulatenously? Should one
added another display setting to the hmip-compmgr.so extension (ie. "display = 2")?
Gervais
