Forum Topic - Building MMSuite from Source Code - make hinstall (Step 4): (22 Items)
I'm trying to build the MM Suite from the source code on Windows Vista based on:
http://community.qnx.com/sf/wiki/do/viewPage/projects.multimedia/wiki/SourceGuide
I'd skipped the "Dependencies" part as the page to scversion update package does not exist.
However, when I get to Step 4 #make hinstall, it comes up with:
C:\FYP\multimedia\trunk>make hinstall
Makefile:4: recurse.mk: No such file or directory
make: *** No rule to make target `recurse.mk'.  Stop.
Any ideas on what went wrong here?
Thanks.
Attachment: Image Screenshot.jpg 39.46 KB
Re: Building MMSuite from Source Code - make hinstall (Step 4)
On Fri, 5 Mar 2010, Seraph Varghese wrote:
Its sounds like your tools are not installed correctly. From the same shell
promt can you do the following:
$ ls $QNX_TARGET/usr/include/mk
ab.mk              linux_x86.mk       nto_mips.mk        os_linux.mk        qconf-linux.mk     qmacros.mk
recurse.mk
build-cfg*         makepriv-nt.bat    nto_ppc.mk         os_nto.mk          qconf-nto.mk       qmake-cfg.mk
buildlist.mk       makepriv-qnx*      nto_sh.mk          os_win32.mk        qconf-win32.mk     qphabtarg.mk
flist-unix*        makepriv-unix*     nto_x86.mk         phapps.mk          qdepfile.mk        qrules.mk
flist-win32*       nto_arm.mk         ntoxdev.mk         prod_utils.mk      qlevel.mk          qtargets.mk
After an install on windows you might have to reboot to get the
env var setup correctly. At the command prompt you can enter
`set`
and see if the QNX_* vars are set properly. If not something went wrong
when you installed the development suite.
Peter
> Thanks.
Hi Peter,
Thanks. A system reboot solved the probem for Step 4 $ make hinstall
However, it's giving me errors for the final step - building the binaries.
$make install
make[5]: *** [exif-entry.o] Error 1
make[5]: Leaving directory `C:/FYP/multimedia/trunk/lib/exif/nto/a/arm-le'
make[4]: *** [install] Error 2
make[4]: Leaving directory `C:/FYP/multimedia/trunk/lib/exif/nto/a'
make[3]: *** [install] Error 2
make[3]: Leaving directory `C:/FYP/multimedia/trunk/lib/exif/nto'
make[2]: *** [install] Error 2
make[2]: Leaving directory `C:/FYP/multimedia/trunk/lib/exif'
make[1]: *** [install] Error 2
make[1]: Leaving directory `C:/FYP/multimedia/trunk/lib'
make: *** [install] Error 2
Attached is a screenshot of the command line output.
Any help would be greatly appreciated.
Thanks.
Attachment: Image Screenshot.jpg 123.05 KB
> Hi Peter,
> $make install
You kind of truncated off some stuff in this and the image. Possibly its a host
based error. I get a warning for the same line, but not an error:
src/foundry/multimedia/lib/exif/exif-entry.c: In function 'exif_entry_get_value':
src/foundry/multimedia/lib/exif/exif-entry.c:591: warning: statement with no effect
Can you attach the entire compile log for lib/exif (shouldn't be too large since
you're failing in the first variant)
Peter
Hi Peter
I have attached the screen shot as you suggested.
Seraph
Attachment: Image screen.jpg 100.9 KB
The libexif component won't build on a Windows host without a slight modification. If you look at the error, you can
figure out which line has a problem and make a change in your local build.
Alternatively, you can choose to not build libexif and also not the exif MDP in the mme tree. Create files called
'Makefile.dnm' in the modules you don't want and a make call above them will not try to build them.
(I can't show you the exact fix since I don't use a Windows host, but I believe there may have been postings about this
somewhere else already.)
Hi
I tried building it on ONX 6.4.1 since Windows was giving errors. The last step gave errors again here. These are
different from the ones on Windows. I have attached a screen shot displaying the errors. What can I do to fix these?
Seraph
Attachment: Image screen.jpg 216.36 KB
Please do a make hinstall and make install of the component present in the
trunk/services/sapi_dvdplayer. For sapi_dvdplayer, you should have installed lib/mmedia.
Once you are successful in the above component, you should be able to build the
io-media/graph/sapi_discplayer.
Hope it helps.
Lakshmi
services/sapi_dvdplayer isn¹t available on foundry.  I recommend just
deleting that part of io-media so that it doesn¹t build.
On 10-03-10 12:39 AM, "Lakshmi Teeka" <community-noreply@qnx.com> wrote:
> lib/mmedia.
> the
> Hope it helps.
> Regards,
> Lakshmi
> http://community.qnx.com/sf/go/post49141
Dan Cardamore   <dcardamore@qnx.com>
QNX Multimedia  http://community.qnx.com/sf/projects/multimedia
Or you can just put a Makefile.dnm in
services/io-media/graph/sapi_discplayer.
But then you'll also need to remove graph/sapi_discplayer from the
MODULES list in services/io-media/target/generic/config.mk
>>Hi,
>>lib/mmedia.
>>the
>>Hope it helps.
>>Regards,
>>Lakshmi
>>_______________________________________________
>>General
Thanks Lakshmi, Dan and Wojtek!!
Well, I tried to add the Makefile in the directory and remove the entry from the Modules List which gave me even more
errors.
Then, I tried Dan's suggestion and deleted the directories with the errors.
The ones that I deleted are: trunk/services/sapi_dvdplayer
and   /trunk/services/io-media/target/generic.
I gave the make install command again and it was error free this time.
Could you please suggest me on how to run it and whether it would be installed correctly since a lot of the commands
mentioned in the quick start guide for the MME do not seem to be working for me. E.g: when I try io-media-generic -M mmf
,dlldir=$QNX_TARGET/x86/lib/dll/mmedia...it says io-media: no such file or directory
Seraph
> the Modules List which gave me even more errors.
> installed correctly since a lot of the commands mentioned in the quick start
> io-media-generic -M mmf,dlldir=$QNX_TARGET/x86/lib/dll/mmedia...it says
You don't have io-media-generic cause you have removed the directory
(services/io-media/target/generic) above that builds it.
You need to leave that in place and apply the changes that Wojtek proposed.
I took the foundry source and stepped into the same errors that you did
and then past them by the suggestions given:
/home/peterm/src/foundry/multimedia/services/io-media/graph/sapi_discplayer/discplayer.c:2708: error:
'MARGI_ERR_MEDIA_AUDIO_STREAM_NOEXI
ST' undeclared (first use in this function)
/home/peterm/src/foundry/multimedia/services/io-media/graph/sapi_discplayer/discplayer.c:2709: error:
'MARGI_ERR_NOMEDIA' undeclared (fir
/home/peterm/src/foundry/multimedia/services/io-media/graph/sapi_discplayer/discplayer.c:2710: error:
'MARGI_ERR_MEDIA_STREAM_CORRUPTION'
/home/peterm/src/foundry/multimedia/services/io-media/graph/sapi_discplayer/discplayer.c:2711: error:
'MARGI_ERR_MEDIA_INCOMPATIBLE_FORMA
/home/peterm/src/foundry/multimedia/services/io-media/graph/sapi_discplayer/discplayer.c:2712: error:
'MARGI_ERR_NAVIGATE' undeclared (fi
/home/peterm/src/foundry/multimedia/services/io-media/graph/sapi_discplayer/discplayer.c:2713: error: 'MARGI_ERR_ACCESS'
 undeclared (firs
/home/peterm/src/foundry/multimedia/services/io-media/graph/sapi_discplayer/discplayer.c:2714: error:
'MARGI_ERR_SERIOUS_READ_ERROR' unde
/home/peterm/src/foundry/multimedia/services/io-media/graph/sapi_discplayer/discplayer.c:2715: error:
'MARGI_ERR_MEDIA_READ_ERROR' undecl
/home/peterm/src/foundry/multimedia/services/io-media/graph/sapi_discplayer/discplayer.c: In function
'discplayer_checkmediastatus':
/home/peterm/src/foundry/multimedia/services/io-media/graph/sapi_discplayer/discplayer.c:2863: warning: too many
arguments for format
cc: /usr/qnx641/host/qnx6/x86/usr/lib/gcc/i386-pc-nto-qnx6.4.0/4.3.3/cc1 error 1
make[6]: *** [discplayer.o] Error 1
make[6]: Leaving directory `/home/peterm/src/foundry/multimedia/services/io-media/graph/sapi_discplayer/a/x86'
make[5]: *** [install] Error 2
make[5]: Leaving directory `/home/peterm/src/foundry/multimedia/services/io-media/graph/sapi_discplayer/a'
make[4]: Leaving directory `/home/peterm/src/foundry/multimedia/services/io-media/graph/sapi_discplayer'
make[3]: Leaving directory `/home/peterm/src/foundry/multimedia/services/io-media/graph'
make[2]: Leaving directory `/home/peterm/src/foundry/multimedia/services/io-media'
make[1]: Leaving directory `/home/peterm/src/foundry/multimedia/services'
-> touch services/io-media/graph/sapi_discplayer/Makefile.dnm
start building again...
/usr/qnx641/host/qnx6/x86/usr/bin/qcc -Vgcc_ntox86 -c -Wc,-Wall -Wc,-Wno-parentheses  -O  -DNDEBUG   -I....
Hi Peter,
Thanks a lot for the detailed explanation. That was great help. I've finished building it successfully.
However, I'm having trouble trying to figure out how to run it.
I've looked through the QuickStart Guide in the introduction to MME. Quite a few of the commands in it did not work.
Could you please help me out with that
Kind Regards,
Seraph
On Fri, 12 Mar 2010, Seraph Varghese wrote:
> Hi Peter,
This is easier if you list the problem(s) that you had at any of the
steps in the quick start guide:
i[Also its useful to confirm that the required services are running and
working (io-audio) first and if not troubleshoot those.]
    1. Requirements
    2. Uninstall the Multimedia Suite (upgrades only)
    3. Install the runtime files
    4. Copy the SQL schema files
    5. Start io-audio
    6. Start the temporary filesystem
    7. Start the QNX database (qdb)
    8. Start mcd
    9. Start io-media
   10. Give the MME some media to play
   11. Start mme
   12. Check the synchronization
   13. Play some music
Please let me know what sort of errors you're encountering on each step.
One thing that you could do to see if you can find all the binaries that you
just built is:
which -laf qdb
which -laf io-media-generic
which -laf io-fs-media
which -laf mme-generic
If this reports no such binary then the install didn't put things into a
searchable path for you (echo $PATH to see what is acceptable)
Peter
Hi Peter
I will list you all the errors I encounter. Do I need to install the runtime files as well? I was thinking that since I
have built the suite from the source code I would not need to do that
Seraph
> Hi Peter
> files as well? I was thinking that since I have built the suite from the
To run them, the products of your build (binaries and libraries) will need to
be available in either your PATH or LD_LIBRARY_PATH for the user on your
system trying to execute them.
You shouldn't need to install the posted runtime archives since you're building
it all.
Peter
Hi Peter
So, in this case, we only start from Step 4 in the Quick Start Guide right?
Say if the build root is in a folder called FYP in root, should I execute the following statement before step 4:
PATH=/root/FYP/trunk
Seraph
On Mon, 15 Mar 2010, Seraph Varghese wrote:
>To: general-multimedia <post49506@community.qnx.com>
>Subject: Re: Building MMSuite from Source Code - make hinstall (Step 4)
> Hi Peter
Take a look in the Neutrino Operating System Docs
-> User Guide
 	-> Configuring your Env
 		-> Environment Var
Any location that binaries/libraries were built to during your compilation will
need to be explictly added to you PATH/LD_LIBRARY_PATH
Peter
Hi Peter
Thanks for that. It worked. I have followed all the steps in the Quick Start Guide and everything is working fine except
 for the very last step, which is giving me an error.
I have a wav file in /media/drive. In the last step, the first two parts work fine, it creates a new track session.
However, when I type in mmecli play, it shows (rc:-1, errno:11): Playing from tracksession fid/bid=0.
I tried this in the mmecli interface as well, where it says PLAY_ERROR(not specified error fid/trksessionid: 2, offset:
0)
I have attached a screen shot as well.
Would you know what the fault could be?
Seraph
Attachment: Image sc.jpg 92.6 KB
On Fri, 19 Mar 2010, Seraph Varghese wrote:
> Hi Peter
> Guide and everything is working fine except for the very last step, which is
> giving me an error.
> fine, it creates a new track session. However, when I type in mmecli play, it
> specified error fid/trksessionid: 2, offset:0)
Using the wave utility you were able to playback a simple wav file to show that
the audio driver was working on the machine?
The troubleshooting section of the quick start guide outlines how to start things
with more debugging info enabled. Restart the noted processes and then collect
the output of sloginfo on the target.
Peter
In  the Quick Start Guide, it is mentioned that there is a sample application called mme-player-simple. I tried to
follow the steps and locate it in the build, but could not do so
I even downloaded and unizpped the patch-630SP2-0315 and could not locate it. It only contains the mme-shuffle, but not
the mme-player-simple and mme-player-multisource
Seraph
> called mme-player-simple. I tried to follow the steps and locate it in the
> It only contains the mme-shuffle, but not the mme-player-simple and
I think that you're refering to the avaiage 1.1 version of the quick start guide. This
application was removed from the 1.2 version since we removed the sample application.
You should use the documentation that matches the version of the software that you're
using.
The current section should look like this:
Sample applications and command-line utilities
You can use the following command line utilities to explore the MME's capabilities:
     * mmebrowse  browse a mediastore
     * mmecli  issue commands corresponding to MME API calls
     * mmexplore  the MME explorer interface command line client
     * mmplexplore  the playlist explorer interface command line client
Peter
