12/05/2012 5:54 AM
post97804
Hi all!
Here some problems when referring to QSA calls.
- snd_pcm_plugin_params fails with error "invalid argument", though the pcm handle is valid and the
snd_pcm_channel_params_t structure is initialized;
- also, snd_pcm_plugin_params fails if the format is set to SND_PCM_SFMT_FLOAT_LE or SND_PCM_SFMT_FLOAT_BE;
- snd_pcm_channel_status_t: the stime member is always to 0, though the time member in snd_pcm_channel_params_t is set
to 1.
Where can be the problem?
Thank you very much!
G.
