Forum Topic - About the mme playlists table: (4 Items)
Hello everyone!
     I can get the media file metadatas from the library table.but the mme internal playlists table is empty,I use the
follow command:
qdbc -d mme "slect * from playlists"
result empty
     please give me some advices ,how can I use the mme internal playlists.thanks very much! otherwise,does the mme
include gracenode itself?how can I get it and manage the playlist.
         thanks very much!
Re: About the mme playlists table
> internal playlists table is empty,I use the follow command:
> result empty
If the MME syncrhonizes a device (say a USB stick) and it finds playlist
files which it recognizes (based on file extension, i.e. something like
".pls" or ".m3u") it will create a playlist entry in the playlists table and
will insert the corresponding playlist entries as fids in the playlistdata
table.
> playlists.thanks very much! otherwise,does the mme include gracenode
>          thanks very much!
Gracenote is not included. You are probably best off to talk to your sales
representative about how to get it.
Gilles
Hi Gilles!
     Thanks for your reply!
     I have some problems need to clarify.
     (1)Is the playlist files(".pls" or ".m3u")  created by myself,or the mme include playlist files itself,only need to
 be syncrhonized?
     (2)My media files is stored in the HardDrive,if I want to get a playlist displayed in the HMI,how should I do ?
     (3)The mme has passed the 3 syn, but the playlists table and playlist_data table is empty,why?
    Looking for your reply ,thanks!
On Tue, 17 Aug 2010, Kailen High wrote:
> Hi Gilles!
>     include playlist files itself,only need to be syncrhonized?
You need to create the playlist files yourself in order for them to be scanned like
the media. Only certain formats will be scanned. (look at the mme.conf file for
the extentions handled in your version)
Once the playlist and playlistdate tables are populated, in the same manner that
you would present data from the library table.
During the sync no playlists were found. You make things more verbose during the sync
to see exactly what is happening. During the file sync pass it will note files that
would be flagged as playlists. If it doesn't find any then there is nothing to do during
the 3rd pass sync.
Do you have playlists on your system that you expected to be found?
Peter
