Forum Topic - [MME] Correct usage of mme_explore_playlist_find_file(): (3 Items)
Hi all,
the documentation in the header file is different from that in the pdf.
API-Call from the Header file:
const mme_explore_info_t *mme_explore_playlist_find_file(mme_hdl_t *hdl, uint64_t msid, const char *entry,  const char *
path,  const char *metadata_types,  uint32_t flags);
Docu - Header file
hdl:= Handle to the MME
Docu - PDF
hdl:= A handle to the MME returned by mme_explore_start()
=> mme_explore_start returns a pointer to a mme_explore_hdl_t
More over in the PDF it is indicated that the result of mme_explore_playlist_find_file() - which is a mme_explore_info_t
 - has to be released using mme_explore_info_free().
=> mme_explore_info_free() is also documented in in different ways:
int mme_explore_info_free(mme_hdl_t *hdl, const mme_explore_info_t *info);
Docu - Header file
Docu - PDF
=> mme_explore_start returns a pointer to a mmm_explore_hdl_t
Is it only a copy and paste typo within the PDF documentation - what I guess?
Do I need a pointer to a mme_explore_hdl_t at all while using mme_explore_playlist_find_file()?
Thanks a lot,
Sebastian
Re: [MME] Correct usage of mme_explore_playlist_find_file()
You may want to have a look at the source of the mmexplore sample util if have not yet.
----- Original Message -----
To: development-multimedia <post49571@community.qnx.com>
Sent: Tue Mar 16 05:16:40 2010
Subject: [MME] Correct usage of mme_explore_playlist_find_file()
Hi all,
Docu - Header file
Docu - PDF
Docu - Header file
Docu - PDF
Thanks a lot,
Sebastian
Development
http://community.qnx.com/sf/go/post49571
I've created an internal PR:75404 to update the documentation. The header files are correct, for that API you need to
pass in the mme_hdl_t.
Gilles
