Re: Build variant PPC (Big Endian SPE)
09/10/2009 1:05 PM
post37763
Hi, Christophe,
This is almost certainly a bug in the IDE. I shall raise it internally
in our tracking system and report back when I have an update.
Cheers,
Christian
On Thu, 2009-09-10 at 12:55 -0400, Christophe Hannoyer wrote:
> Hello,
> I get a problem when using the IDE 4.6.0 (QNX 6.4.1 including now the new variant for PPC BE SPE) when I try to setup
a new "QNX System Builder Project". Then I select "Create Generic" and select "ppcspe". When the project was create if
now I tried to add new binaries for example in this project the list is empty. If I do the same with for example ppcbe
and try to include new binaries I get a list of files from $QNX_TARGET/ppcbe/...
> In the image properties I can see that the "CPU Type" was set to "ppcspe" and if I look in the directory $QNX_TARGET/
there is no ppcspe directory but a ppcbe-spe.
> For a test only I rename the directory $QNX_TARGET/ppcbe-spe to $QNX_TARGET/ppcspe and then the list of binaries was
there.
> After doing all these changes I can build and use the image.
> Is there someone else with experiences with this issue?
> Thank you,
> Christophe
> http://community.qnx.com/sf/go/post37760
________________________________________________________________________
Christian W. Damus
Software Developer, IDE Team
QNX Software Systems
01/19/2010 11:27 AM
post45496
Hi, Christophe,
This problem is fixed in the current development stream. The fix will be available in the IDE 4.7 release (SDP 6.4.2).
Cheers,
Christian
