Forum Topic - Cannot set working directory for (serial) debugging session: (1 Item)
when I setup a serial debugging configuration,
I see errors in the GDB console, the command that fails is
set qnxremotecwd <mypath>
as a consequence the working directory of the proces is not set as expected.
from typing help set in the gdp window I would suspect,
that
set nto-cwd <mypath>
should have been used there. Is there a solution for this, or have I made
another error.
(Configuration is momentics 4.6.0, Beagleboard)
thanks for the help
Stefan
