Re: Integration with QNX Momentics IDE
09/09/2009 8:34 AM
post37629
Hi, Gidi,
In the Momentics IDE, if you create a C/C++ project of the non-QNX
variety, then the default toolchain selection is the QCC compiler
driver. This applies to all of the basic templates, for managed-make
and for simple makefile projects.
This lets you use QCC to build projects for the Neutrino platform in
projects for which the Eclipse CDT provides API (such as IBuildInfo)
that you can use for your own tooling purposes. The QCC toolchain
integration provides certain critical indexing functions, such as
discovery of the Neutrino include paths and macro definitions,
environment variables, and possibly more, according to your current
qconfig target selection.
HTH,
Christian
On Wed, 2009-09-09 at 03:23 -0400, Gidi Gal wrote:
> Hi Christian,
> I have a question regarding your reply. I understood from your reply that QNX C/C++ projects are not managed-make
projects. You also mentioned that there is an integration of the QCC toolchain into the managed build system. If QNX C\C
++ are not managed-make projects, what is the meaning of integration of the QCC toolchain into managed build system ?
> Thanks,
> Gidi
