Forum Topic - IDE 4.7 Integration build 20090805 is available for download.: (9 Items)
The first IDE 4.7 Integration build 20090805 is now available for download.
See change log and details here:
http://community.qnx.com/sf/wiki/do/viewPage/projects.ide/wiki/DownloadIDE4.7
Re: IDE 4.7 Integration build 20090805 is available for download.
Are the workspaces and .cproject backward and forward compatible with 4.6?
RE: IDE 4.7 Integration build 20090805 is available for download.
We have a requirement for workspace backward compatibility. The
requirement statement is:
Upgradeable Workspace: IDE 4.7 shall allow customers to import existing
workspaces from IDE 4.6 (SDP 6.4.1) and IDE 4.5 (SDP 6.4.0) into the new
IDE. The customer projects shall preserve all custom settings and be
buildable from the new IDE.
Based on our developer verification this requirement is met.
For "forward" compatibility - if you mean workspace created in IDE 4.7
to be able to use by previous IDE, we have never claimed supporting it.
Andy
Sent: Friday, August 07, 2009 11:08 AM
To: general-ide
Subject: Re: IDE 4.7 Integration build 20090805 is available for
download.
download.
4.6?
It make sense to me the workspace many not be forward compatible, but I think the project definition files ( .cproject,
.project, .settings ) should be?  If I work on a project with 4.7 and commit changes which affects the project's
definition files,  someone with 4.6 should be able to work on that same project?
> From: Andy Jin [mailto:community-noreply@qnx.com]
> Sent: Friday, August 07, 2009 11:20 AM
> To: general-ide
> Subject: RE: IDE 4.7 Integration build 20090805 is available for
> download.
> new
> Thanks,
> Andy
> To: general-ide
> download.
> download.
> 4.6?
> http://community.qnx.com/sf/go/post35476
At first glance due to the inclusion of new Eclipse platform and new
CDT, project metadata forward compatibility is not guaranteed. Eclipse
and CDT may have new metadata or deprecate old metadata.
We can add this as one of our verification requirement.
If our testing shows that you can use the ".project" and ".cproject"
files in the previous IDE, I don't think you can re-use the ".settings"
since in IDE 4.7 we start including the P2 engine which changes the way
it saves product metadata dramatically.
Sent: Friday, August 07, 2009 11:23 AM
To: general-ide
download.
think the project definition files ( .cproject, .project, .settings )
affects the project's definition files,  someone with 4.6 should be able
> To: general-ide
> download.
existing
> new
it.
> Thanks,
> Andy
> To: general-ide
> download.
> download.
> 4.6?
Ok then what about storing the .settings files (or even directory) on a per IDE/CDT Version, so that a project can be
open by various version of the IDE.
I don't know about how other people do thing but the way I like to do thing is when a IDE comes out (beta or not), it's
deployed to a limited number of users ( 1-2 ). They learn the new stuff and then when they feel ready, everybody get the
 upgrade.  That way there aren't lots of people going through the same learning curve at the same time, and the first
users can help the other to shorted the learning curve.
> Sent: Friday, August 07, 2009 11:34 AM
> To: general-ide
> download.
> To: general-ide
> download.
> able
> > To: general-ide
> > download.
> existing
> > new
> 4.7
> it.
> > Thanks,
> > Andy
> > To: general-ide
> > download.
> > download.
> > 4.6?
> http://community.qnx.com/sf/go/post35480
To clarify that we are talking the same thing :-), when you say
".settings" do you mean those settings files under
<workspace_location>/.metadata directory?
I don't see any ".settings" under any of my project directory. Maybe I
don't have the same project type you are using?
Sent: Friday, August 07, 2009 11:41 AM
To: general-ide
download.
per IDE/CDT Version, so that a project can be open by various version of
the IDE.
thing is when a IDE comes out (beta or not), it's deployed to a limited
feel ready, everybody get the upgrade.  That way there aren't lots of
first users can help the other to shorted the learning curve.
> Sent: Friday, August 07, 2009 11:54 AM
> To: general-ide
> download.
I'm talking about .settings in the project directory.  I'm using C++ Project.  It contains a file named org.eclipse.cdt.
core.prefs.  Maybe that is because we have used the setting "Enable project specific settings" in the past.  That would
mean the .settings directory could be removed if that setting is disable?
> To: general-ide
> download.
> of
> the IDE.
> http://community.qnx.com/sf/go/post35486
Ah, I see what you mean. Yes the ".settings" still being used when
"Enable project specific settings" is selected.
For C/C++ project CDT writes to it. So this also needs to be tested for
forward compatibility.
Andy
Sent: Friday, August 07, 2009 11:59 AM
To: general-ide
download.
> To: general-ide
> download.
Project.  It contains a file named org.eclipse.cdt.core.prefs.  Maybe
settings" in the past.  That would mean the .settings directory could be
