08/04/2009 2:18 PM
post35196
> Using version 4.6.0 Build ID I20090510
> In the IDE help, I do not see any OS help files.
> I see the IDE docs, workbench C/C++ dev guide, Derby and Subversive
> How do I get the OS docs to show up ?
> Per an earlier post, I deleted my indexes but nothing new showed up
> Suggestions ?
> Thanks !
> Dave
Elena suggested somewhere else:
a) remove momentics/4.5 from user home
b) start in new workspace
c) check file in <ide install>/eclipse/links - it has to point to correct documentation folder
Jeevan
08/05/2009 7:41 AM
post35234
- Is your IDE part of the SDP 6.4.0 install or is it a standalone zip file downloaded from F27?
- Do you see a link file under "eclipse/links" folder? If yes, check the content of the link file for the "path=<
location_of_os_doc>" and make sure you have the O.S. doc installed under that location. The O.S. doc should be installed
in a "eclipse" folder under that location.
- After checking the link file, remove your IDE config area and restart it. On windows the config area is "C:\Documents
and Settings\<username>\momentics\4.6", on Linux is "<homedir>/.momentics/4.6".
Sent: Tue 04/08/2009 1:46 PM
To: general-ide
Subject: Missing help files
Suggestions ?
Thanks !
Dave
General
http://community.qnx.com/sf/go/post35192
