Re: No source available for "main()"
08/04/2009 11:33 PM
post35216
Just checking - are you definitely debugging the _g version i.e. a build
that has symbols in it ?
By default, new projects are setup to create a 'release' and a 'debug'
version. Release has no symbols or debug in it, debug does...
Regards
Dave
Eric Dong wrote:
> > In you debug launch the "Source" tab, can you check to see if you
> have the
> > correct path to your project?
> > From: Eric Dong [mailto:community-noreply@qnx.com]
> > Sent: Tue 04/08/2009 8:00 AM
> > To: general-ide
> > Subject: No source available for "main()"
> > Hello,
> > I am debugging in IDE 4.5.0, with the new version gdb 6.7.10. When i
> tried to
> > debug, it pops out the msg " No source available for "main()"", but
> i can
> > still resume the programe, but could not set breakpoints on it.
> where should i
> > fix? thanks.
> > Eric
> Thanks. The source path is included in default. besides, i add my
> project to the source path including x86/o, x86/o-g. but don't work. i
> don't have such a problem before.
> http://community.qnx.com/sf/go/post35175
Dave Bott (dbott@qnx.com) Field Applications Engineer
QNX Software Systems, Inc. Cell:408 391-3535
San Jose CA
Join Foundry27 <http://community.qnx.com> - the new QNX developer forum.
