Forum Topic - Sharing projects using the 4.6 IDE: (2 Items)
It has been brought to my attention that under the 4.6 IDE, when you import a BSP and check its project properties, the
Search Paths use absolute references to the project location? Instead of using paths relative to the workspace. This
apparently prevents sharing projects among team members (absolute references conflict). Under the 4.5 IDE the search
paths were relative, allowing sharing a project file between team mates.
Is this a "bug" or expected behavior because of the new way to import and build BSPs under 4.6?
RE: Sharing projects using the 4.6 IDE
There was not a requirement to support sharing System Builder project.
However I agree that we should use relative path references. Please file
a PR for a change request.
Andy
From: Gervais Mulongoy [mailto:community-noreply@qnx.com]
Sent: Thursday, July 30, 2009 4:59 PM
To: general-ide
Subject: Sharing projects using the 4.6 IDE
import a BSP and check its project properties, the Search Paths use
relative to the workspace. This apparently prevents sharing projects
search paths were relative, allowing sharing a project file between team
mates.
