Forum Topic - converting a common.mk file to use the IDE : (2 Items)
I have an old make file for a project that I would like to convert over and use the QNX Momentics IDE to build.
I have a common.mk file that GNU make uses.  When I make my application all I do now is >make and things just build.
Is there a guide or an easy way to take the common.mk file that I now and use it with the IDE project environment?
Many thanks to any response in advace
etm
emarsh@wideopenwest.com
Re: converting a common.mk file to use the IDE
I don't understand why you want to convert it... You just create make project and IDE would run a make for you exactly
same as from command line.
There is a wiki article explaining different types of IDE projects and how you can set them up:
http://community.qnx.com/sf/wiki/do/viewPage/projects.ide/wiki/ProjectsBuildAndIDE
> etm
> http://community.qnx.com/sf/go/post31664
