06/10/2009 4:27 PM
post31426
You have to be root or setuid root on the proxy binary that launches the server. Or you can change port to something
above 1000.
Binary is in /opt/qnx641/host/linux/x86/usr/qde/eclipse/plugins/com.qnx.tools.ide.tftp_4.6.0/os/linux/proxy
(or whatever version you have)
Douglas Bailey wrote:
> I've moved my desktop over to linux, and I've run into a problem I can't figure out...
> I use the IDE's tftp server to serve boot images to a board on my desktop. Running under linux, the IDE can't start
up tftpd -- it gives a message "Cannot start server: error: Unable to bind to server port".
> I've made sure that xinetd doesn't use port 69:
> root@qnxws7581:/etc/xinetd.d# netstat -anp | grep ":69"
> The server worked fine under Windows...
> btw, this is Ubuntu 9.04 if that makes any difference.
> Anybody have any ideas?
> Thanks,
> Doug
> http://community.qnx.com/sf/go/post31423
06/10/2009 4:29 PM
post31427
Hi, Doug,
Just to be sure: you are running the IDE as root, right? (I see that
you are root in your terminal snippets) The IDE will run as whatever
user has your GNOME session, which may not be root if you logged in to
XDM as yourself.
Is there any more specific error message in the .metadata/.log file in
your workspace directory?
Cheers,
Christian
> Thanks,
> Doug
________________________________________________________________________
Christian W. Damus
Software Developer, IDE Team
QNX Software Systems
