Forum Topic - Missing something obvious: (10 Items)
So I will ask and I am sure someone will point it out.
I am currently running the 0402 build of 4.6 on Windows XP.  It is installed and being used with a QNX 632 installation.
  Regardless of my challenges from previous posts it is generally working well.
Today I decided I would try to get a remote debugging session going.  I went and found the newer version of qconn:
NAME=qconn
DESCRIPTION=QNX Connecter
DATE=2008/12/03-14:09:26-EST
STATE=stable
HOST=compbuild2
USER=pspbuild
VERSION=632-1225
TAGID=2389
After I had problems, I created the default Hello World ANSI C project and tried to debug it on my target.  My target is
 a VMware instance running the same 632 developers install that I use in Windows.  I updated it with the above mentioned
 qconn and that is it.
When I try to start it up under the debugger, the application crashes with a SIGSEGV at 0xb0031bdc - it never gets to
main().
If I go to the target and run the uploaded exe from /tmp, it runs fine.  I can also run gdb on it and it works as
expected.
I assume I am missing something that I need to upgrade on the target?
As far as qconn goes, I can browse everything from the target perspective (looking at processes, file system, etc..).
Any ideas?
Rick..
Re: Missing something obvious
This almost certainly means that the libc.so in the vmware targets image doesn't match the libc.so in your $QNX_TARGET
installation.  Regardless of my challenges from previous posts it is generally working well.
> NAME=qconn
> STATE=stable
> HOST=compbuild2
> USER=pspbuild
> VERSION=632-1225
> TAGID=2389
is a VMware instance running the same 632 developers install that I use in Windows.  I updated it with the above
mentioned qconn and that is it.
main().
expected.
> Any ideas?
> Thanks,
> Rick..
> http://community.qnx.com/sf/go/post29568
cburgess@qnx.com
You are correct - on the target:
# cksum libc.so*
3747485823     583420 libc.so
 151268457     414052 libc.so.1
3747485823     583420 libc.so.2
On Windows:
C:\QNX630\target\qnx6\x86\lib>cksum libc.so*
2180402056     462292 libc.so
2180402056     462292 libc.so.2
So how do I tell which ones is correct, and since they are both libc.so.2 why are they not compatible?
I will copy the target version to Windows since I "know" it works in QNX ;-) and confirm that fixes the problem.
Rick..
But did you check which version was used for /proc/boot/libc.so?
> # cksum libc.so*
> On Windows:
> Thanks,
> Rick..
> http://community.qnx.com/sf/go/post29573
cburgess@qnx.com
I'll be honest, I have been very confused with the whole shared library thing under qnx.  Specifically, the version
number and how gcc selects the right one when linking and then which one is used at run time, etc, etc.
Is there be some reading I can do on the subject?
Kevin
This is not specific to qnx. Here is brief introduction (in
my own words):
When linking program, program linker (ld) looks for ".so"
file. E.g. -lfoo looks for file named "libfoo.so". Once
found, it reads its soname which is typically something like
"libfoo.so.N" where N is a number.
For example, -lc will look for libc.so, then read from it
its soname: libc.so.3. (To see library's soname, you can do
something like: readelf -a libc.so | grep SONAME)
This soname is what is stored in executable's dynamic
section and can be listed by
readelf -a <binary> | grep NEEDED.
At runtime, dynamic linker (ldd) uses name stored in NEEDED
when searching for actual file.
Note that typically libfoo.so would be softlink to "the
latest", e.g. libfoo.so.3.
Note2: To determine which exactly libraries will be pulled
in on the target at runtime, type "ldd <binary>" on the
target. This will tell you exactly from which directories
will shared libraries be taken (affected by LD_LIBRARY_PATH
and LD_PRELOAD env. vars.)
Hope this helps,
Aleksandar
Ok, I copied the target versions of the libc.so* over the files in the windows target directory and recompiled
HelloWorld.  Unfortunately that seems to make no difference and it still crashes the same way as before.
I attached the verbose console output from gdb when it fails if that is any help.
Attachment: Text gdb_output.txt 5.5 KB
Unfortunately, no.
But there are a few things I would try. First, I would
update gdb. GDB that came with 6.3.2 is 5.2.1 and is rather
old.
First, try using newer gdb which you can download from our
community site
(http://community.qnx.com/sf/frs/do/listReleases/projects.toolchain/frs.gdb)
Next I would try to move qconn out of picture (for
diagnosing this only). To do the tests I am suggesting, open
cmd.exe, change directory to where your binary "helloworld"
is and start gdb, for example:
C:\myworkspace\helloworld\x86\o-g\> ntox86-gdb
(gdb)
On your target, start pdebug like this:
# pdebug 8010
Back to your host, type in gdb this command:
(gdb) target qnx 192.168.3.128:8010
(gdb) upload HelloWorld /tmp/HelloWorld
(gdb) b main
(gdb) run /tmp/HelloWorld
It should stop at main and you should be able to step/continue.
Let me know if it worked.
Aleksandar
Unfortunately (or fortunately), I reinstalled both my windows and vmware
installations and it all appears to work now.  I am currently running from
the released 6.3.2 windows and qnx host installations.  On top of this I
have the 0402 ide installation and the appropriate qconn and it all appears
to be working.
Thanks for the ideas tho.
Rick..
On Tue, May 26, 2009 at 6:44 AM, Aleksandar Ristovski <
community-noreply@qnx.com> wrote:
> windows target directory and recompiled HelloWorld.  Unfortunately that
> any help.
> Unfortunately, no.
> old.
> community site
> (gdb)
> # pdebug 8010
> (gdb) b main
> Thanks,
> Aleksandar
> http://community.qnx.com/sf/go/post30023
Rick Duff
rgduff@gmail.com
Mitch Hedberg<http://www.brainyquote.com/quotes/authors/m/mitch_hedberg.html>;
- "My fake plants died because I did not pretend to water them."
Did you also update $QNX_TARGET/x86/usr/lib/ldqnx.so.2?  That's the file that gdb would use to find
the breakpoint address, and on windoze it's not a link...
> http://community.qnx.com/sf/go/post29575
cburgess@qnx.com
