Re: Instrumented kernel usage with debugger
04/24/2009 12:31 PM
post28031
I believe they were added in 640
-E enables all events
-c is the equivalent to -n0
without -E you would also have to add
TraceEvent( _NTO_TRACE_ADDALLCLASSES );
to your code, before the _NTO_TRACE_START call.
You should also call
TraceEvent( _NTO_TRACE_DELALLCLASSES ); after the stop too.
Colin
Eric Dong wrote:
> Thanks, but may i know the meaning of -E and -c ? I am using QNX 6.3.2.
> Eric
>> the best way to do this is to start tracelogger in daemon mode, where it is
>> ready to go but not logging.
>> eg
>> # tracelogger -d1 -E -w -c -S32M -M -v &
>> and then in your application, start tracing with
>> TraceEvent( _NTO_TRACE_START );
>> and stop with
>> TraceEvent( _NTO_TRACE_STOP );
>> TraceEvent( _NTO_TRACE_FLUSHBUFFER ); /* make sure to get the last partial
>> buffer out */
>> Eric Dong wrote:
>>> Hello, i would like to use the instrumented kernel to check threads
>> execution in my application in debug mode. I have set up the onboard to use
>> tracelogger, etc. But i have no ideas when should i start the program such
>> that the tracelogger will log the time period that i am really interested. Btw
>> , the time option in tracelogger must be set to avoid the default 0 second?
>>> Thanks,
>>> Eric
>>> General
>>> http://community.qnx.com/sf/go/post28004
>> cburgess@qnx.com
> http://community.qnx.com/sf/go/post28030
cburgess@qnx.com
