Forum Topic - Problem with IDE 4.5 appearance and functionality : (19 Items)
I was surprised that I'm the only who have such problem.
After first start of IDE 4.5 it looks fine. But if i try to enter a new SVN repository location I see that something
wrong with the window: the authentification group box is empty (see screenshot). Then I try to import existing project,
right click on project explorer -> import. Then I click one of the fields, but all of them not responding. I think that
there're more problems, wich I haven't found.
I have 64 bit Win Vista on 2*AMD Opteron 2.6 GHz, 4 Gb memory.
Do anyone knows what's wrong?
Attachment: Image momentics_bug.jpg 46.04 KB
Re: Problem with IDE 4.5 appearance and functionality
We have several 64 bit users reported different problems. Out IDE
bundled an Eclipse 32 bit version which is not meant to be used on a 64
bit platform although some 64 bit users are using it without problem.
Do you have a 32 bit host and can you try again?
> http://community.qnx.com/sf/go/post25207
Thanks for your reply.
Yes, on 32-bit everything is ok. But I still want to make it work under my OS.
There was another experience on my colleague PC, wich is also under Vista 64. First he installed IDE 4.5, and everythig
was ok, than he installed the mind mapping software Personal Brain. After that the problem as I described appeared. The
essential thing is that the Personal Brain updating Java VM. Then he uninstalled Personal Brain and all started to work
fine again. But than he installed 64 bit Matlab, which is also uses Java, and again the same problems.
That's why I think that the problem with Java, but I don't know what exactly the problem is.
The addon softwares may have modified the PATH environment variable and
added their updated Java VM to the path. You can force Eclipse to use
its own Java VM by using the command option "-vm".
Open a Windows command prompt, run this command:
<IDE_INSTALL_DIR>\qde.exe -vm <IDE_INSTALL_DIR>\jre
replace the <IDE_INSTALL_DIR> with the actual directory where you
install the IDE.
everythig was ok, than he installed the mind mapping software Personal Brain. After that the problem as I described
appeared. The essential thing is that the Personal Brain updating Java VM. Then he uninstalled Personal Brain and all
started to work fine again. But than he installed 64 bit Matlab, which is also uses Java, and again the same problems.
> http://community.qnx.com/sf/go/post25211
Hi, Andy, Mihail,
An alternative to updating your shortcut is to add the command-line
parameters to the qde.ini file.  Add, above the "-vmargs" line (that is
important), each argument on a separate line:
  -vm
  <IDE_INSTALL_DIR>\jre\bin\javaw.exe
In either case, the path needs to include the Java executable, not just
the JRE home folder.
Cheers,
Christian
> install the IDE.
> > General
> http://community.qnx.com/sf/go/post25217
________________________________________________________________________
Christian W. Damus
Software Developer, IDE Team
QNX Software Systems
Didn't help unfortunately.
Can you attach  your IDE log file? It should be under  your workspace directory, ".metadata/.log" file.
Sure. Thanks for your efforts.
Attachment: Text .log 558.94 KB
You log file shows that you don't have "QNX_CONFIGURATION" environment variable set. Do you have the full Momentics
installed? or you downloaded the IDE separately?
Can you open a windows command prompt and do a "set" to see if you have "QNX_*" environment variables?
Yes, it's in attachment.
Attachment: Image win_env.jpg 122.18 KB
The fact that your "QNX_CONFIGURATION" points to "C:\Program Files (x86)\QNX Software Systems" might be causing the
problem. This (x86) in the path is 64 bit Vista specific, right?
Can you run the "qconfig" command from your windows command prompt and send the output?
May I suggest you manually create a "C:\Program Files" directory and copy the "QNX Software Systems" folder there?
RE: Problem with IDE 4.5 appearance and functionality
> From: Andy Jin [mailto:community-noreply@qnx.com]
> Sent: March-25-09 4:47 PM
> To: general-ide
> Subject: Re: Problem with IDE 4.5 appearance and functionality
> (x86)\QNX Software Systems" might be causing the problem. This (x86) in
Doesn't create any problem for me.
> send the output?
> http://community.qnx.com/sf/go/post25261
Yes, under Vista 64 there're both "Program files" and "Program files (x86)". First for 64-bit applications, second for
32 bit. I've tried to copy momentics to both, noothing changed.
Please try to connect from your Vista64 machine  to SVN repository from
command line or using torttoise utility. I believe this is rather SVN
problem than IDE.
> http://community.qnx.com/sf/go/post25290
Thanks, but the problem is rather fundamental. Here in attachment another bug with Run window. And it's not last.
Attachment: Image run_window.jpg 49.26 KB
> http://community.qnx.com/sf/go/post25346
Anyway, I see SVN server running on your computer. Could you please stop
it for a short while and try to start IDE and look at the last dialog
once again?
Also, if you can try IDE on the clean Vista machine (VM is also OK), it
would be also nice.
SVN Sevrver service is currently disabled. I also tryed to install IDE 4.5 on my notebook with Vista. Woks fine in spite
 of installed matlab.
So we can come to the conclusion: some third-party software installed on
your desktop causes this  problem. You can detect which one. In the mean
time it would be nice if you rename your .log file, then run IDE, open
run configuration dialog (I hope the problem still visible well), then
close IDE and send new created .log (I hope, it should be created).
Alex.
spite of installed matlab.
> http://community.qnx.com/sf/go/post25402
Hurray! I've found the solution.
I've opened task manager started to kill unnecessary processes one by one. After I killed ABBYY Lingvo x3 (dictationary
software) and started momentics everything become normal. Than restarted Lingvo and look into settings. There I  find a
suspicious features "Translate word by clicking Ctrl+Ins+Ins" and the same with Ctrl+C+C. After disabling that
everything become normal again.
Thank you Andy, Christian and Alex.
