Forum Topic - Enabling assembly source in the build (.s or .asm files): (12 Items)
I am using QNX momentics 6.4.0 tools. I am able to create projects with C source and build properly. If I add any
assembly source .s or .asm files, it is not getiing added into the build. I tried drag and drop copy as wells as linking
 resource method. None of them are taking Assembly code into the build. If I right click on the file, I don't see the
option to comiple.  Can any one help how to include the Asssembly source into the build?
Re: Enabling assembly source in the build (.s or .asm files)
On 23/03/2009 6:41 AM, Venkatarao Patnaik Balivada wrote:
> http://community.qnx.com/sf/go/post24973
Works for me. Where do you place your assembler file?
Tried 2 options
1) Under project directory, with drag and drop copy
2) Under project directory, linked to the directory containging the ASM files
On 23/03/2009 8:13 AM, Venkatarao Patnaik Balivada wrote:
> Tried 2 options
> http://community.qnx.com/sf/go/post24983
Then please send me an example project and console log from  your build.
It is actually not including the file in the build. It doesn't give any error.
Find the .project file inline(not able to attach), I am not sure what is the project file. Find the .cproject file in
the next message.
<?xml version="1.0" encoding="UTF-8"?>
<projectDescription>
	<name>h264dec_lib</name>
	<comment></comment>
	<projects>
	</projects>
	<buildSpec>
		<buildCommand>
			<name>com.qnx.tools.ide.qde.core.cbuilder</name>
			<triggers>clean,full,incremental,</triggers>
			<arguments>
				<dictionary>
					<key>org.eclipse.cdt.core.errorOutputParser</key>
					<value>com.qnx.tools.ide.qde.core.IntelCErrorParser;com.qnx.tools.ide.qde.core.QdeExtraMakeErrorParser;org.eclipse.
cdt.core.MakeErrorParser;org.eclipse.cdt.core.GCCErrorParser;org.eclipse.cdt.core.GASErrorParser;org.eclipse.cdt.core.
GLDErrorParser;org.eclipse.cdt.core.VCErrorParser;</value>
				</dictionary>
				<dictionary>
					<key>org.eclipse.cdt.make.core.enableAutoBuild</key>
					<value>false</value>
				</dictionary>
				<dictionary>
					<key>build_return_code</key>
					<value>Status WARNING: com.qnx.tools.ide.qde.core code=0  null children=[Status WARNING: com.qnx.tools.ide.qde.core
 code=0 There are warnings...
Looks like I am not able to include all contents
<?fileVersion 4.0.0?>
<cproject>
<storageModule moduleId="org.eclipse.cdt.core.settings">
<cconfiguration id="org.eclipse.cdt.core.default.config.2076916013">
<storageModule buildSystemId="org.eclipse.cdt.core.defaultConfigDataProvider" id="org.eclipse.cdt.core.default.config.
2076916013" moduleId="org.eclipse.cdt.core.settings" name="Configuration">
<externalSettings/>
<extensions>
<extension id="com.qnx.tools.ide.qde.core.QDEBynaryParser" point="org.eclipse.cdt.core.BinaryParser"/>
</extensions>
</storageModule>
<storageModule moduleId="org.eclipse.cdt.core.externalSettings"/>
<storageModule moduleId="org.eclipse.cdt.core.pathentry">
<pathentry kind="src" path=""/>
<pathentry kind="out" path=""/>
<pathentry kind="con" path="com.qnx.tools.ide.qde.QDE_PROJECT_CONTAINER"/>
</storageModule>
<storageModule moduleId="org.eclipse.cdt.make.core.buildtargets">
<buildTargets>
<target name="build" path="" targetID="com.qnx.tools.ide.qde.core.cbuilder">
<buildCommand>make</buildCommand>
<buildArguments></buildArguments>
<buildTarget>all</buildTarget>
<stopOnError>false</stopOnError>
<useDefaultCommand>true</useDefaultCommand>
<runAllBuilders>true</runAllBuilders>
</target>
<target name="clean" path="" targetID="com.qnx.tools.ide.qde.core.cbuilder">
<buildTarget>clean</buildTarget>
</target>
<target name="rebuild" path="" targetID="com.qnx.tools.ide.qde.core.cbuilder">
<buildTarget>clean all</buildTarget>
</target>
</buildTargets>
</storageModule>
<storageModule moduleId="org.eclipse.cdt.core.language.mapping"/>
</cconfiguration>
</storageModule>
</cproject>
trying to add .project file again
	<comment></comment>
	<projects>
	</projects>
	<buildSpec>
		<buildCommand>
			<arguments>
				<dictionary>
				</dictionary>
				<dictionary>
				</dictionary>
				<dictionary>
I don't need these files, but I still need example project (or at least
its File System tree & common.mk) and your console log after such  build
that failed to compile assembler code
> 	<comment></comment>
> 	<projects>
> 	</projects>
> 	<buildSpec>
> 		<buildCommand>
> 			<arguments>
> 				<dictionary>
eclipse.cdt.core.MakeErrorParser;org.eclipse.cdt.core.GCCErrorParser;org.eclipse.cdt.core.GASErrorParser;org.eclipse.cdt
.core.GLDErrorParser;org.eclipse.cdt.core.VCErrorParser;</value>
> 				</dictionary>
> 				<dictionary>
> 				</dictionary>
> 				<dictionary>
core code=0 There are warnings null]</value>
> 				</dictionary>
> 				<dictionary>
> 					<key>org.eclipse.cdt.make.core.enableFullBuild</key>
> 					<value>true</value>
> 				</dictionary>
> 				<dictionary>
> 					<key>org.eclipse.cdt.make.core.build.target.inc</key>
> 					<value>all</value>
> 				</dictionary>
> 				<dictionary>
> 					<key>org.eclipse.cdt.make.core.enabledIncrementalBuild</key>
> 					<value>true</value>
> 				</dictionary>
> 				<dictionary>
> 					<key>org.eclipse.cdt.make.core.build.location</key>
> 					<value></value>
> 				</dictionary>
> 				<dictionary>
> 					<key>org.eclipse.cdt.make.core.build.target.clean</key>
> 					<value>clean</value>
> 				</dictionary>
> 				<dictionary>
> 					<key>org.eclipse.cdt.make.core.build.command</key>
> 					<value>make</value>
> 				</dictionary>
> 				<dictionary>
> 					<key>org.eclipse.cdt.make.core.enableCleanBuild</key>
> 					<value>true</value>
> 				</dictionary>
> 				<dictionary>
> 					<key>org.eclipse.cdt.make.core.build.target.full</key>
> 					<value>all</value>
> 				</dictionary>
> 				<dictionary>
> 					<key>org.eclipse.cdt.make.core.useDefaultBuildCmd</key>
> 					<value>true</value>
> 				</dictionary>
> 				<dictionary>
> 					<key>org.eclipse.cdt.make.core.build.target.auto</key>
> 					<value>all</value>
> 				</dictionary>
> 				<dictionary>
> 					<key>org.eclipse.cdt.make.core.stopOnError</key>
> 				</dictionary>
> 			</arguments>
> 		</buildCommand>
> 	</buildSpec>
> 	<natures>
> 		<nature>org.eclipse.cdt.core.cnature</nature>
> 		<nature>com.qnx.tools.ide.qde.core.qnxnature</nature>
> 	</natures>
> 	<linkedResources>
> 		<link>
> 			<name>EXTRA_SRCVPATH_lib</name>
What is example project? Do you mean source code? Another doubt I have is,
1) How do I save the project in a project file which can be opened in IDE in some other machine?
2) From the documentation, I can see only the "export" option to save as zip file.
Please find the common.mk below
My directory structure is
h264dec/include    - contains API file
h264dec/lib           - *.c and *.h files
h264dec/lib/arm     - *.asm files
# This is an automatically generated record.
# The area between QNX Internal Start and QNX Internal End is controlled by
# the QNX IDE properties.
ifndef QCONFIG
QCONFIG=qconfig.mk
endif
include $(QCONFIG)
ifndef QNX_INTERNAL
QNX_INTERNAL=$(PROJECT_ROOT)/.qnx_internal.mk
endif
#===== USEFILE - the file containing the usage message for the application.
USEFILE=
#===== CCFLAGS - add the flags to the C compiler command line.
CCFLAGS+=-w3 -O3 -DMB_PADDING0 -mcpu=arm1136j-s  \
	-fsigned-char
#===== EXTRA_INCVPATH - a space-separated list of directories to search for include files.
EXTRA_INCVPATH+=D:/projects/h264dec/lib $(PROJECT_ROOT)  \
	D:/projects/h264dec/include
#===== EXTRA_SRCVPATH - a space-separated list of directories to search for source files.
EXTRA_SRCVPATH+=D:/projects/h264dec/lib  \
	D:/projects/h264dec/lib/arm
include $(MKFILES_ROOT)/qmacros.mk
include $(QNX_INTERNAL)
include $(MKFILES_ROOT)/qtargets.mk
OPTIMIZE_TYPE_g=none
OPTIMIZE_TYPE=$(OPTIMIZE_TYPE_$(filter g, $(VARIANTS)))
console log
D:/projects/h264dec/lib/vlc.h: In function 'iReadSyntaxElementIntra4x4PredMode':
D:/projects/h264dec/lib/vlc.h:238: warning: unused variable 'next_input_byte'
D:/projects/h264dec/lib/vlc.h:236: warning: unused variable 'num_bits'
D:/projects/h264dec/lib/vlc.h: In function 'iDecodeVLC_common':
D:/projects/h264dec/lib/vlc.h:265: warning: unused variable 'next_input_byte'
D:/projects/h264dec/lib/vlc.h: In function 'iReadSyntaxElement_CoefToken':
D:/projects/h264dec/lib/vlc.h:302: warning: unused variable 'next_input_byte'
D:/projects/h264dec/lib/vlc.h:298: warning: unused variable 'num_bits'
D:/projects/h264dec/lib/vlc.h: In function 'iReadSyntaxElement_Level_VLCN':
D:/projects/h264dec/lib/vlc.h:337: warning: unused variable 'next_input_byte'
D:/projects/h264dec/lib/vlc.h: In function 'iReadSyntaxElement_Level_VLC0':
D:/projects/h264dec/lib/vlc.h:375: warning: unused variable 'next_input_byte'
D:/projects/h264dec/lib/header.c: At top level:
D:/projects/h264dec/lib/read_bitstream.h:104: warning: 'iPeekBits' defined but not used
D:/projects/h264dec/lib/read_bitstream.h:116: warning: 'iSkipBits' defined but not used
D:/projects/h264dec/lib/vlc.h:151: warning: 'iReadSyntaxElementVLC_CBPIntra' defined but not used
D:/projects/h264dec/lib/vlc.h:169: warning: 'iReadSyntaxElementVLC_CBPInter' defined but not used
D:/projects/h264dec/lib/vlc.h:187: warning: 'iReadSyntaxElementVLC_se' defined but not used
D:/projects/h264dec/lib/vlc.h:202: warning: 'iReadSyntaxElementVLC_ue' defined but not used
D:/projects/h264dec/lib/vlc.h:217: warning: 'iReadSyntaxElementFLC' defined but not used
D:/projects/h264dec/lib/vlc.h:233: warning: 'iReadSyntaxElementIntra4x4PredMode' defined but not used
D:/projects/h264dec/lib/vlc.h:295: warning: 'iReadSyntaxElement_CoefToken' defined but not used
D:/projects/h264dec/lib/vlc.h:331: warning: 'iReadSyntaxElement_Level_VLCN' defined but not used
D:/projects/h264dec/lib/vlc.h:369: warning: 'iReadSyntaxElement_Level_VLC0' defined but not used
C:/QNX640/host/win32/x86/usr/bin/qcc -V4.2.4,gcc_ntoarm -c  -Wc,-Wall -Wc,-Wno-parentheses -Wc,-fno-builtin -w3 -O3 -
DMB_PADDING0 -mcpu=arm1136j-s -fsigned-char             -I. -IC:/ide-4.5-workspace/h264dec_lib/arm/a.le -IC:/ide-4.5-
workspace/h264dec_lib/arm/a-le-g -IC:/ide-4.5-workspace/h264dec_lib/arm -IC:/ide-4.5-workspace/h264dec_lib -ID:/projects
/h264dec/lib -ID:/projects/h264dec/lib/arm -ID:/projects/h264dec/lib -IC:/ide-4.5-workspace/h264dec_lib -ID:/projects/
h264dec/include -IC:/QNX640/target/qnx6/usr/include      -EL  -g       -DVARIANT_a -DVARIANT_le -DVARIANT_g -
DBUILDENV_qss  D:/projects/h264dec/lib/image.c
In file included from D:/projects/h264dec/lib/global.h:52,
                 from D:/projects/h264dec/lib/image.c:52:
D:/projects/h264dec/lib/defines.h:185:1: warning: "max" redefined
In file included from D:/projects/h264dec/lib/image.c:46:
C:/QNX640/target/qnx6/usr/include/stdlib.h:242:1: warning: this is the location of the previous definition
D:/projects/h264dec/lib/defines.h:186:1: warning: "min" redefined
C:/QNX640/target/qnx6/usr/include/stdlib.h:248:1: warning: this is the location of the previous definition
In file included from D:/projects/h264dec/lib/annexb.h:34,
                 from D:/projects/h264dec/lib/image.c:67:
D:/projects/h264dec/lib/read_bitstream.h: In function 'iPeekBits':
D:/projects/h264dec/lib/read_bitstream.h:108: warning: unused variable 'next_input_byte'
In file included from D:/projects/h264dec/lib/image.c:74:
D:/projects/h264dec/lib/vlc.h: In function 'iReadSyntaxElementVLC_CBPIntra':
D:/projects/h264dec/lib/vlc.h:156: warning: unused variable 'next_input_byte'
D:/projects/h264dec/lib/vlc.h: In function 'iReadSyntaxElementVLC_CBPInter':
D:/projects/h264dec/lib/vlc.h:174: warning: unused variable...
Thanks. .s extension works with even linked files.
Please change extension .asm to .s or .S
> ifndef QCONFIG
> QCONFIG=qconfig.mk
> endif
> include $(QCONFIG)
> ifndef QNX_INTERNAL
> endif
> USEFILE=
> 	-fsigned-char
> http://community.qnx.com/sf/go/post25065
