Forum Topic - Create Project failure - resurrected: (20 Items)
Colin and others already posted simillar things.
I get a null pointer exception on QNX/none - C/C++ project creation.
This only happens when I have switch my enviornment to use 6.4.0 build configs, when I use environment for 6.3.2
everything works fine.
The settings for 6.4.0 are correct - I can work using cmd line.
I don't see a solution for this problem in the other threads.
Even when I start with a new/empty eclipse configuration folder, I get an indexer error message on startup.
>  An internal error occurred during: "Initialize Indexing".
>  java.lang.NullPointerException"
find attached my .log file
if you need the eclipse config folder give me a ping
thanks
/hp
Attachment: Text .log 255.11 KB
Re: Create Project failure - resurrected
Which build are you using? I believe it has been fixed recently.
AW: Create Project failure - resurrected
It's logged in the .log file, it's the latest one 20090304
-----Ursprüngliche Nachricht-----
Von:	Alex Chapiro [mailto:community-noreply@qnx.com]
Gesendet:	Di 17.03.2009 17:39
An:	general-ide
Cc:
Betreff:	Re: Create Project failure - resurrected
General
http://community.qnx.com/sf/go/post24585
Attachment: Text winmail.dat 3.24 KB
What is QNX/none - C/C++ project creation?
C/C++ Project - Executable - QNX toolchain?
Do you have any extra compilers installed on 6.4.0?
> thanks
> /hp
> http://community.qnx.com/sf/go/post24573
it is
project new
   - QNX C/C++ project
   - C/C++ Project
will try to be more specific next time.
I have separate installations of 6.4.0 and 6.3.2 toolchains
and I am switching my environment (QNX_HOST/TARGET and PATH)
Von:	Elena Laskavaia [mailto:community-noreply@qnx.com]
Gesendet:	Di 17.03.2009 18:37
An:	general-ide
Cc:
> thanks
> /hp
General
http://community.qnx.com/sf/go/post24588
Attachment: Text winmail.dat 3.9 KB
Re: AW: Create Project failure - resurrected
You also have to switch MAKEFLAGS var, may not be relevant to your crash though. Do you have QNX_CONFIGURATION set?
> it is
> project new
>    - QNX C/C++ project
>    - C/C++ Project
> An:     general-ide
> Cc:
> build configs, when I use environment for 6.3.2 everything works fine.
>  > thanks
>  > /hp
>  > _______________________________________________
>  > General
> Informationen. Wenn Sie nicht der richtige Adressat sind oder diese
> Absender und loeschen Sie diese Mail. Das unerlaubte Kopieren sowie die
> you are not the intended recipient (or have received this e-mail in
> unauthorized copying, disclosure or distribution of the contents in this
> http://community.qnx.com/sf/go/post24591
AW: AW: Create Project failure - resurrected
QNX_CONFIGURATION is set but not changed for switching from 6.3.2 to 6.4.0
I have my different XML files there that are used for the IDE choice in Preferneces/QNX
I've removed MAKEFLAGS from my env, is that tragic?
Gesendet:	Di 17.03.2009 18:51
An:	general-ide
Cc:
Betreff:	Re: AW: Create Project failure - resurrected
> it is
> project new
>    - QNX C/C++ project
>    - C/C++ Project
> An:     general-ide
> Cc:
>  > thanks
>  > /hp
>  > General
General
http://community.qnx.com/sf/go/post24593
Attachment: Text winmail.dat 4.31 KB
Re: AW: AW: Create Project failure - resurrected
If you don't use qnx project it is not tragic. If you do recursive make project may want that. Should not crash on
project creation because it that though.
QNX_CONFIGURATION does not change - correct. Do you have any extra compilers installed in 6.4.0, or it is stock 6.4.0 (
in the other words did you modify /opt/qnx640 directory (or you are on windows then it is C:/qnx640))?
> Preferneces/QNX
> An:     general-ide
> Cc:
>  > it is
>  > project new
>  >    - QNX C/C++ project
>  >    - C/C++ Project
>  > An:     general-ide
>  > Cc:
>  >  > thanks
>  >  > /hp
>  >  > General
>  > General
> Mauser
AW: AW: AW: Create Project failure - resurrected
I am running windows XP and I didn't install extra compilers on top of 6.4.0
I have a c:\path\qnx640, and a c:\path\qnx632
Gesendet:	Di 17.03.2009 19:00
An:	general-ide
Cc:
Betreff:	Re: AW: AW: Create Project failure - resurrected
> Preferneces/QNX
> An:     general-ide
> Cc:
>  > it is
>  > project new
>  >    - QNX C/C++ project
>  >    - C/C++ Project
>  > An:     general-ide
>  > Cc:
>  >  > thanks
>  >  > /hp
>  >  > General
>  > General
> Mauser
Attachment: Text winmail.dat 4.7 KB
Re: AW: AW: AW: Create Project failure - resurrected
That is interesting... Non standard paths for installation. What is c:\path - is it literally "path" or it contains
spaces or some other weird symbols?
Can you please post file from  %QNX_CONFIGURATION%/qconfig/qnx_software_development_platform_6.4.0.xml
> An:     general-ide
> Cc:
> project may want that. Should not crash on project creation because it
> that though.
> 6.4.0
>  > Preferneces/QNX
>  > An:     general-ide
>  > Cc:
>  >  > it is
>  >  > project new
>  >  >    - QNX C/C++ project
>  >  >    - C/C++ Project
>  >  > An:     general-ide
>  >  > Cc:
> creation.
AW: AW: AW: AW: Create Project failure - resurrected
full path for 6.4.0 is:
D:\p4\qnx640
and for 6.3.2 it is
D:\p4\qnx\qssl\nto\qnx632\Trunk
there is no space nor any none ASCII character in path
and please don't ask me for any reason for this(!)
To "learn" this you would have to do it like Thomas did it, spent some time at HBAS.
Gesendet:	Di 17.03.2009 19:12
An:	general-ide
Cc:
Betreff:	Re: AW: AW: AW: Create Project failure - resurrected
> An:     general-ide
> Cc:
> that though.
> 6.4.0
>  > Preferneces/QNX
>  > An:     general-ide
>  > Cc:
>  >  > it is
>  >  > project new
>  >  >    - QNX C/C++ project
>  >  >    - C/C++ Project
>  >  > An:     general-ide
>  >  > Cc:
> creation.
>  >  >  > I don't see a solution for this problem in the other...
Attachment: Text winmail.dat 7.37 KB
Re: AW: AW: AW: AW: Create Project failure - resurrected
I still need %QNX_CONFIGURATION%/qconfig/qnx_software_development_platform_6.4.0.xml file and values of all env vars
your modified ( QNX_* and PATH)
> D:\p4\qnx640
> and for 6.3.2 it is
> time at HBAS.
> An:     general-ide
> Cc:
> c:\path - is it literally "path" or it contains spaces or some other
> weird symbols?
> of 6.4.0
>  > An:     general-ide
>  > Cc:
>  > that though.
>  > 6.4.0
> choice in
>  >  > Preferneces/QNX
>  >  > An:     general-ide
>  >  > Cc:
> crash
>  >  >  > it is
>  >  >  > project new
>  >  >  >    - QNX C/C++ project
>  >  >  >    - C/C++ Project
>  >  >  > An:     general-ide
>  >  >  > Cc:
AW: AW: AW: AW: AW: Create Project failure - resurrected
strange, I had attached a ZIP to my last reply ...
hm one more time ...
BTW: there is no file name "qnx_software_development_platform_6.4.0.xml" in qconfig folder see ZIP contents
Gesendet:	Di 17.03.2009 19:28
An:	general-ide
Cc:
Betreff:	Re: AW: AW: AW: AW: Create Project failure - resurrected
> D:\p4\qnx640
> and for 6.3.2 it is
> time at HBAS.
> An:     general-ide
> Cc:
> weird symbols?
> of 6.4.0
>  > An:     general-ide
>  > Cc:
>  > that though.
>  > 6.4.0
> choice in
>  >  > Preferneces/QNX
>  >  > An:     general-ide
>  >  > Cc:
> crash
>  >  >  > it is
>  >  >  > project new
>  >  >  >    - QNX C/C++ project
>  >  >  >    - C/C++ Project
>  >  >  > Von:   ...
Attachment: Text winmail.dat 10.66 KB
Re: AW: AW: AW: AW: AW: Create Project failure - resurrected
webmail is driving me crazy
additional reply through browser
env is
QNX_CONFIGURATION=C:\Program Files\QNX Software Systems
QNX_HOST=D:/p4/qnx640/host/win32/x86
QNX_TARGET=D:/p4/qnx640/target/qnx6
Path=c:\Tools\ruby\bin;C:\Program Files\RSA SecurID Token Common;C:\Program Files\PC Connectivity Solution\;C:\Program
Files\ThinkPad\Utilities;C:\perl\Perl\bin\;C:\WINNT\system32;C:\WINNT;C:\WINNT\System32\Wbem;C:\Program Files\perforce;C
:\Program Files\QNX Software Systems\bin;D:\p4\qnx640\host\win32\x86\usr\bin;C:\Program Files\QuickTime\QTSystem\;C:\
Program Files\Intel\Wireless\Bin\;C:\Program Files\ThinkPad\ConnectUtilities;C:\Program Files\Subversion\bin;C:\Program
Files\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files\Common Files\Lenovo;C:\Program Files\SlickEdit\win;C:\
Program Files\Microsoft Visual Studio\Common\Tools\WinNT;C:\Program Files\Microsoft Visual Studio\Common\MSDev98\Bin;C:\
Program Files\Microsoft Visual Studio\Common\Tools;C:\Program Files\Microsoft Visual Studio\VC98\bin
Attachment: Text qconfig.zip 1.82 KB
Alex still thinks your $QNX_HOST/etc/qcc is polluted. Can you send listing of this directory?
> env is
C:\Program Files\QNX Software Systems\bin;D:\p4\qnx640\host\win32\x86\usr\bin;C:\Program Files\QuickTime\QTSystem\;C:\
> http://community.qnx.com/sf/go/post24613
AW: AW: AW: AW: AW: AW: Create Project failure - resurrected
I will do that tomorrow when I am back in office ...
Gesendet:	Di 17.03.2009 20:15
An:	general-ide
Cc:
Betreff:	Re: AW: AW: AW: AW: AW: Create Project failure - resurrected
> env is
General
http://community.qnx.com/sf/go/post24615
Attachment: Text winmail.dat 4.05 KB
I have to say: blame, blame on my IS guys
and glory for Alex.
I didn't install additional compilers on top of my 6.4.0, ... but my IS did!
I had ICC configuration files inside my QNX_HOST/etc/qcc
as I removed these the IDE is working again.
Would be nice if IDE could give some more specific error messages though ;-)
thanks
/hp
>Gesendet: Dienstag, 17. März 2009 20:16
>An: general-ide
>> env is
>> C:\WINNT\System32\Wbem;C:\Program Files\perforce;C:\Program
>Files\QNX
>> Files\QuickTime\QTSystem\;C:\Program
>> Files\Subversion\bin;C:\Program Files\ATI
>> Files\Lenovo;C:\Program Files\SlickEdit\win;C:\Program
>Files\Microsoft
>> Studio\Common\MSDev98\Bin;C:\Program Files\Microsoft Visual
>> General
>General
Re: AW: AW: AW: AW: AW: AW: Create Project failure - resurrected
After Colin complains I just changed compiler info reading this way that
instead of raising  NPE IDE ignores unknown stuff. Next integration
build should be more tolerant.
> and glory for Alex.
> thanks
> /hp
>> An: general-ide
>>> env is
>> Files\QNX
>> Files\Microsoft
>>> General
>> General
I just tried the same build and did not have any problem with project
creation.
It would be nice if you send archived $(QNX_HOST)/etc/qcc directory and
your curret environment (env or set, whatever is applicable for your case).
> in Preferneces/QNX
> An:     general-ide
> Cc:
> > it is
> > project new
> >    - QNX C/C++ project
> >    - C/C++ Project
> > An:     general-ide
> > Cc:
> > > thanks
> > > /hp
> > > General
> > General
> Michael Mauser
> > you are not the intended recipient (or have received this...
OK, I will do that as soon as I am back in office - I don't have access to my working env right now -> tomorrow
An:	general-ide
Cc:
creation.
> in Preferneces/QNX
> An:     general-ide
> Cc:
> > it is
> > project new
> >    - QNX C/C++ project
> >    - C/C++ Project
> > An:     general-ide
> > Cc:
> > > thanks
> > > /hp
> > > General
> > General
> Michael Mauser
> > E-Mail irrtuemlich erhalten haben,...
Attachment: Text winmail.dat 4.68 KB
