Forum Topic - 4.6 licensing issue - gcc OK: Page 1 of 2 (29 Items)
I just installed the latest 4.6 drop (20090304) on my Dell D820 laptop on Fedora Core 10
I first installed 6.4.0, then replaced the eclipse directory with the 4.6 eclipse directory. Was that not OK ?
I activated the license and it said it was OK. Regardless, I should have 30 days. I think.
gcc works fine and built a hello world for me from a shell
When I run the IDE, I get a license problem
Popup says: "License Message Reason: License Check Failure
/opt/qnx640/host/linux/x86/usr/lib/libqnxlic.sao: Can't load IA 32-bit .so on a IA 32-bit platform"
which seems unfortunate.
There are no specific installation or 'how to run' notes that I can find - I just ran 'qde' - is that wrong ?
The IDE runs, but all licensed components are disabled.
What's wrong ?
Thanks !
Dave
Here's the complete log
*** Date: Sunday, March 15, 2009 10:05:31 PM GMT-08:00
*** Platform Details:
*** System properties:
eclipse.buildId=I20090304
eclipse.commands=-os
linux
-ws
gtk
-arch
x86
-showsplash
-launcher
/opt/qnx640/host/linux/x86/usr/qde/eclipse/qde
-name
Qde
--launcher.library
/opt/qnx640/host/linux/x86/usr/qde/eclipse/plugins/org.eclipse.equinox.launcher.gtk.linux.x86_1.0.101.R34x_v20080805/
eclipse_1115.so
-startup
/opt/qnx640/host/linux/x86/usr/qde/eclipse/plugins/org.eclipse.equinox.launcher_1.0.101.R34x_v20080819.jar
-vm
/opt/qnx640/host/linux/x86/usr/qde/eclipse/jre/bin/../lib/i386/client/libjvm.so
eclipse.ee.install.verify=false
eclipse.home.location=file:/opt/qnx640/host/linux/x86/usr/qde/eclipse/
eclipse.launcher=/opt/qnx640/host/linux/x86/usr/qde/eclipse/qde
eclipse.product=com.qnx.tools.ide.momentics.ide
eclipse.startTime=1237183352988
eclipse.vm=/opt/qnx640/host/linux/x86/usr/qde/eclipse/jre/bin/../lib/i386/client/libjvm.so
eclipse.vmargs=-Dpath=$QNX_HOST/usr/bin:$PATH
-Xms256M
-Xmx512M
-XX:MaxPermSize=128m
-Djava.class.path=/opt/qnx640/host/linux/x86/usr/qde/eclipse/plugins/org.eclipse.equinox.launcher_1.0.101.R34x_v20080819
.jar
eof=eof
file.encoding=UTF-8
file.encoding.pkg=sun.io
file.separator=/
java.awt.graphicsenv=sun.awt.X11GraphicsEnvironment
java.awt.printerjob=sun.print.PSPrinterJob
java.class.path=/opt/qnx640/host/linux/x86/usr/qde/eclipse/plugins/org.eclipse.equinox.launcher_1.0.101.R34x_v20080819.
jar
java.class.version=49.0
java.endorsed.dirs=/opt/qnx640/host/linux/x86/usr/qde/eclipse/jre/lib/endorsed
java.ext.dirs=/opt/qnx640/host/linux/x86/usr/qde/eclipse/jre/lib/ext
java.home=/opt/qnx640/host/linux/x86/usr/qde/eclipse/jre
java.io.tmpdir=/tmp
java.library.path=/opt/qnx640/host/linux/x86/usr/qde/eclipse/jre/lib/i386/client:/opt/qnx640/host/linux/x86/usr/qde/
eclipse/jre/lib/i386:/opt/qnx640/host/linux/x86/usr/lib::/usr/lib/xulrunner-1.9:/usr/lib/xulrunner-1.9
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.5.0_11-b03
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.5
java.vendor=Sun Microsystems Inc.
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.5.0_11
java.vm.info=mixed mode, sharing
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems...
Re: 4.6 licensing issue - gcc OK
Dave,
We haven't tested FC10 as it's not a formally supported platform. Before we get hold of a FC10 system to test, there are
 several small steps to narrow down the issue:
1) After  your installed SDP 6.4.0, have you tried to run the bundled IDE (4.5.0)? Did it work?
2) Can you check to see if you have read access to "/opt/qnx640/host/linux/x86/usr/lib/libqnxlic.so"? If yes, can you do
 a "ldd" on that library?
3) Can you do a "cat `which qde`" and see if that qde shell script sets the LD_LIBRARY_PATH to where the "libqnxlic.so"
is?
4) Do you set any special "java.library.path" variable in your "qde.ini" file or from your command line?
5) Would you be able to remove your $HOME/.momentics/4.6 directory and try again?
Should be same problem with IDE 4.5. Is it 64bit or 32?
You have to run $QNX_HOST/usr/bin/qde.
> What's wrong ?
> Thanks !
> Dave
> linux
> -ws
> gtk
> -arch
> x86
> -showsplash
> -launcher
> -name
> Qde
> --launcher.library
eclipse_1115.so
> -startup
> -vm
> -Xms256M
> -Xmx512M
R34x_v20080819.jar
> eof=eof
> file.encoding=UTF-8
> file.separator=/
.jar
> java.io.tmpdir=/tmp
> java.vm.vendor=Sun...
run_qde.sh DOES run $QNX_HOST/usr/bin/qde...
$ cat /opt/qnx640/run_qde.sh
#!/bin/sh
cd "/opt/qnx640/"
"/opt/qnx640/host/linux/x86/usr/bin/qde"
>> What's wrong ?
>> Thanks !
>> Dave
>> linux
>> -ws
>> gtk
>> -arch
>> x86
>> -showsplash
>> -launcher
>> -name
>> Qde
>> --launcher.library
eclipse_1115.so
>> -startup
>> -vm
>> -Xms256M
>> -Xmx512M
R34x_v20080819.jar
>> eof=eof
>> file.encoding=UTF-8
>> file.separator=/
R34x_v20080819.jar
>> java.io.tmpdir=/tmp
>> java.specification.vendor=Sun...
And what is the answer to my first question?
> #!/bin/sh
> cd "/opt/qnx640/"
>>> What's wrong ?
>>> Thanks !
>>> Dave
>>> linux
>>> -ws
>>> gtk
>>> -arch
>>> x86
>>> -showsplash
>>> -launcher
>>> -name
>>> Qde
>>> --launcher.library
/eclipse_1115.so
>>> -startup
>>> -vm
>>> -Xms256M
>>> -Xmx512M
R34x_v20080819.jar
>>> eof=eof
>>> file.encoding=UTF-8
>>> file.separator=/
R34x_v20080819.jar
>>> java.io.tmpdir=/tmp
Thanks for the suggestions.
This is 32-bit Fedora Core 10 - my laptop is not 64-bit capable, but it is dual core.
Reverting to stock (6.4.0) IDE 4.5 was worse - it crashed... see attached bug report.
It got a long way before it crashed - asked me about which workspace to use etc.
It had created a workspace directory and a .metadata directory, but no .log file
I tried it as both root and non-root.
For Andy's questions about libqnxlic.so
[root@demoPC lib]# pwd
[root@demoPC lib]# ls -la libqnxlic.so
-rwxrwxr-x 1 root root 453932 2009-03-15 22:55 libqnxlic.so
[root@demoPC lib]# ldd libqnxlic.so
	linux-gate.so.1 =>  (0x00505000)
	libpthread.so.0 => /lib/libpthread.so.0 (0x00cee000)
	libc.so.6 => /lib/libc.so.6 (0x00e88000)
	/lib/ld-linux.so.2 (0x002db000)
[root@demoPC lib]# cat `which qde`
#!/usr/bin/env sh
export PATH=$QNX_HOST/usr/bin:$PATH
export LD_LIBRARY_PATH=$QNX_HOST/usr/lib:$LD_LIBRARY_PATH
$QNX_HOST/usr/qde/eclipse/qde
[root@demoPC lib]# set|grep QNX
QNX_CONFIGURATION=/etc/qnx
QNX_HOST=/opt/qnx640/host/linux/x86
QNX_JAVAHOME=/opt/qnx640/_jvm
QNX_TARGET=/opt/qnx640/target/qnx6
So, yes, I can access it, ldd it, and it appears to be in LD_LIBRARY_PATH
I have not knowingly set *anything* in qde.ini or the command line.
I did remove the .momentics dir and try again - same result.
This should be pretty easy to try - Fedora Core 10 is not hard to obtain...
Dave
Attachment: Text Momentics-bugreport.txt 21.64 KB
RE: 4.6 licensing issue - gcc OK
> From: Dave Bott [mailto:community-noreply@qnx.com]
> Sent: March-16-09 11:53 AM
> To: general-ide
> Subject: Re: 4.6 licensing issue - gcc OK
> is dual core.
I'm pretty sure if it's dual core, it supports 64 bits.
 No, it really doesn't - it's a Core 2, not a Core 2 Duo
Per Windows, it is a T2500.
Wikipedia says this is a Yonah:
Sent: Mon 16/03/2009 8:55 AM
To: general-ide
Subject: RE: 4.6 licensing issue - gcc OK
> To: general-ide
> is dual core.
General
http://community.qnx.com/sf/go/post24444
Attachment: Text winmail.dat 3.61 KB
Re: RE: 4.6 licensing issue - gcc OK
Rats - hit the send key by mistake...
Wikipedia reference:
http://en.wikipedia.org/wiki/List_of_Intel_microprocessors#Intel_Core
AFAIK it's the first dual core that came out - 32 bits only - Core 2 Duo were then 64-bit...
FC10 64-bit complained about lack of 64-bit support when I tried it too...
Not that it should matter here of course...
Cheers
Dave
RE: RE: 4.6 licensing issue - gcc OK
Thanks for correcting me !
> Sent: March-16-09 12:06 PM
> To: general-ide
> Subject: Re: RE: 4.6 licensing issue - gcc OK
> too...
> Cheers
> Dave
> http://community.qnx.com/sf/go/post24448
Me too.  I guess not all D820's are created equal! :-)
>> -----Original Message-----
>> To: general-ide
>> too...
>> Cheers
>> Dave
>> General
> http://community.qnx.com/sf/go/post24451
cburgess@qnx.com
Unfortunately it is not support platform. Do you have a crash log? Check configuration area for a log
$HOME/.momentics/4.5/
Try to remove $HOME/.momentics and re-start.
> #!/usr/bin/env sh
> Thanks
> Dave
> http://community.qnx.com/sf/go/post24443
I'm also having licensing issue (Ubuntu 8.10 64 bit) , I can compile/edit/debug, but can't run any of the QNX specific
tools.
no qnxlic in java.library.path
The 4.6 version is started with a script Elena posted which ends with:
/home/mcharest/eclipse/qde "$@"
> Sent: March-16-09 11:57 AM
> To: general-ide
> it is dual core.
> to use etc.
> no .log file
> > #!/usr/bin/env sh
> LD_LIBRARY_PATH
> obtain...
> > Thanks
> > Dave
> > General
> http://community.qnx.com/sf/go/post24445
qde script that he is running has this already. Library is loaded but failed to load some other library or resolve some
other symbols.
 tools.
>> To: general-ide
>> it is dual core.
>> to use etc.
>> no .log file
>>> #!/usr/bin/env sh
>> LD_LIBRARY_PATH
>> obtain...
>>> Thanks
>>> Dave
>>> General
>> General
> http://community.qnx.com/sf/go/post24452
4.5 crash can be related to xulrunner problems, but if you have licensing issues after you fix xulrunner problems, you
would still get into them.
If for some reason there are some binary compatibility problems with Fedora Core 10 and our licensing library nothing we
 can do here until this platform
is officially supported or it required by the customer as PSP.
> #!/usr/bin/env sh
> Thanks
> Dave
Thanks Elena/Andy.
Just checking - are we not adding *any* new supported Linux distros with IDE 4.6 ? FC10 and Ubunutu 8.10 are pretty
mainstream these days... And then there's 64-bit too...
Is the list still whatever was supported for 6.4.0 ?
Dave
Sent: Mon 16/03/2009 9:06 AM
To: general-ide
> #!/usr/bin/env sh
> Thanks
> Dave
General
http://community.qnx.com/sf/go/post24450
Attachment: Text winmail.dat 5.72 KB
It is supported for 6.4.1 looks like
QMS7058-080 The following host platforms shall be supported:
     * Windows
           o 2000, XP Professional, Vista
           o Vista 64-bit
     * Linux
           o Suse 11
           o RedHat Enterprise Linux 4.0, 5.0
           o RedHat Enterprise Linux 5.1 Server 64 Bit Edition
           o Fedora 10
           o Ubuntu 8.04 LTS, 8.10
     * QNX Neutrino 6.4.1 x86 host (excluding IDE)
     * QNX Neutrino 6.4.1 x86 host on VMWare Workingstation 6.5, VMWare Player 2.5 (excluding IDE)
     * QNX Neutrino 6.4.1 x86 host on Microsoft VirtualPC 2007 (excluding IDE)
Dave Bott wrote:
> Thanks Elena/Andy.
> IDE 4.6 ? FC10 and Ubunutu 8.10 are pretty mainstream these days... And
> Thanks
> Dave
> To: general-ide
> licensing issues after you fix xulrunner problems, you would still get
> into them.
> Fedora Core 10 and our licensing library nothing we can do here until
> this platform
> it is dual core.
> to use etc.
> no .log file
>  > #!/usr/bin/env sh
> obtain...
>  > Thanks
>  > Dave
>  > General
I googled it. This error message is wrong because of some bug in jvm. It is trying to tell us something else.
Try to check permission on this library and all library it is references. Make sure it is rx for your user.
Dave Bott wrote:
> Thanks Elena/Andy.
> Thanks
> Dave
> To: general-ide
> into them.
> this platform
> it is dual core.
> to use etc.
> no .log file
>  > #!/usr/bin/env sh
> obtain...
>  > Thanks
>  > Dave
>  > General
> http://community.qnx.com/sf/go/post24454
RE: 4.6 licensing issue - gcc OK - solution
Joy !
SELinux was getting in the way of the 4.6 code.
Specifically, it said it was preventing qde from loading libqnxlic.so which requires text relocation.
Obligingly, the report it generated  even explained how to fix it:
chcon -t textrel_shlib_t 'opt/qnx640/host/linux/x86/usr/lib/libqnxlic.so
This did indeed let 4.6 start up - stock 4.5 still fails with the xrunner issue.
Maybe that's your [roblem too Mario ?
Dave
Sent: Mon 16/03/2009 9:20 AM
To: general-ide
Dave Bott wrote:
> Thanks Elena/Andy.
> Thanks
> Dave
> To: general-ide
> into them.
> this platform
> it is dual core.
> to use etc.
> no .log file
>  > #!/usr/bin/env sh
> obtain...
>  > Thanks
>  > Dave
>  > General
Attachment: Text winmail.dat 7.62 KB
Re: 4.6 licensing issue - gcc OK - solution
You had SELinux enabled and still was able to install SDP? Didn't the
installer failed with licensing check because it uses the same
"libqnxlic.so"?
In terms of xrunner issue, it's known in Eclipse 3.3.x which IDE 4.5
bundled with. It's fixed in Eclipse 3.4.x which IDE 4.6 has now.
Dave Bott wrote:
> Joy !
> xrunner issue.
> Dave
> To: general-ide
> Dave Bott wrote:
> > Thanks Elena/Andy.
> > Thanks
> > Dave
> > To: general-ide
> > into them.
> > this platform
> > it is dual core.
> > to use etc.
> > no .log file
> >  > #!/usr/bin/env sh
Btw. SELinux problem described in the Installation Instructions on wiki page (instructions on how to turn it off):
http://community.qnx.com/sf/wiki/do/viewPage/projects.ide/wiki/Builds_Tau_Integration
Dave Bott wrote:
> Joy !
> xrunner issue.
> Dave
> To: general-ide
> Dave Bott wrote:
>  > Thanks Elena/Andy.
>  > Thanks
>  > Dave
>  > To: general-ide
>  > into them.
>  > this platform
>  > it is dual core.
>  > to use etc.
>  > no .log file
>  >  > #!/usr/bin/env sh
Thanks Elena - I looked for installation and release notes where I
downloaded 4.6 - nothing there. Perhaps we could link them there as we
do for regular downloads ?
Perhaps the note can be extended to specifically explain the kinds of
problems that SELinux can cause ? Switching it off seems quite draconian
- isn't it there for a reason ?
Dave
> Dave Bott wrote:
> > Joy !
> > xrunner issue.
> > Dave
> > To: general-ide
> > Dave Bott wrote:
> >  > Thanks Elena/Andy.
> distros with
> days... And
> >  > Thanks
> >  > Dave
> >  > To: general-ide
> still get
> >  > into them.
> >  > this platform
> capable, but
> >  > it is dual core.
> workspace
> >  > to use etc.
> directory, but
> >  > no .log file
Ok I add your note in there and link.
> Thanks
> Dave
>> Dave Bott wrote:
>>> Joy !
>>> xrunner issue.
>>> Dave
>>> To: general-ide
>>> Dave Bott wrote:
>>>  > Thanks Elena/Andy.
>> distros with
>> days... And
>>>  > Thanks
>>>  > Dave
>>>  > To: general-ide
>> still get
>>>  > into them.
>>>  > this platform
>> capable, but
>>>  > it is dual core.
> Sent: March-16-09 12:38 PM
> To: general-ide
> Subject: RE: 4.6 licensing issue - gcc OK - solution
> Joy !
> xrunner issue.
Unfortunately not. I don't have SELinux installed, as far as I can tell..
Just to be on the safe side I tried chcon but that didn't change anything.
Thanks!
Mario your problem is because you did not have right LD_LIBRARY_PATH, and I as understand setting it properly resolves
it.
There is no other workarounds, it has to be set. What is what qde script does (usr/bin/qde).
> Thanks!
> http://community.qnx.com/sf/go/post24477
