Forum Topic - Cut and Paste/Drag and Drop Issue with IDE 4.6: (7 Items)
Under Windows XP and IDE 4.6,
I am able to open the Target File System Navigator under the QNX System Info perspective.
I am able to drag files from Windows Explorer to the directories displayed in the Navigator.
What I am not able to do, as I was able to do under 4.5.1, is to copy and paste files from Windows Explorer to the
Navigator
When I right-click in the Navigator and click paste nothing appears to happen.
I am transferring large files, so I know when the transfer starts as I get a progress window.
If I use drag and drop, no problem, but copy and past appears not to work.
Re: Cut and Paste/Drag and Drop Issue with IDE 4.6
That would be an eclipse bug. What type of file is it?
Navigator
> http://community.qnx.com/sf/go/post24387
Files are a 'tar' file and an md5 file
Hmm works for me. In what type of project you are pasting? Anything is in the .log file?
> http://community.qnx.com/sf/go/post24438
Pardon my ignorance, but where do I look for .log?
<workspace>/metadata/.log
See also http://community.qnx.com/sf/wiki/do/viewPage/projects.ide/wiki/IDEGeneralFAQ
> http://community.qnx.com/sf/go/post24680
Here are the various errors reported in .log. I didn't anything that I thought was related to 'copying'
!MESSAGE Internal Error
!STACK 1
org.eclipse.core.internal.resources.ResourceException: Found model provider extension with no identifier; ignoring
extension.
	at org.eclipse.core.internal.resources.mapping.ModelProviderDescriptor.fail(ModelProviderDescriptor.java:47)
!MESSAGE WARNING: Blocked recursive attempt to close part org.eclipse.cdt.ui.editor.CEditor while still in the middle of
 activating it
!STACK 0
java.lang.RuntimeException: WARNING: Blocked recursive attempt to close part org.eclipse.cdt.ui.editor.CEditor while
still in the middle of activating it
	at org.eclipse.ui.internal.WorkbenchPage.closeEditors(WorkbenchPage.java:1282)
!MESSAGE A handler conflict occurred.  This may disable some commands.
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2009-03-17 08:51:32.965
!MESSAGE Conflict for 'AUTOGEN:::org.eclipse.ui.cheatsheets.actionSet/org.eclipse.ui.cheatsheets.actions.
CheatSheetHelpMenuAction':
HandlerActivation(commandId=AUTOGEN:::org.eclipse.ui.cheatsheets.actionSet/org.eclipse.ui.cheatsheets.actions.
CheatSheetHelpMenuAction,
!MESSAGE Error reading help table of contents file /"com.qnx.doc.ide_en/../com.qnx.doc.ide_en_user_guide/toc.xml"
(skipping file)
!STACK 0
java.io.FileNotFoundException
	at org.eclipse.help.internal.toc.TocFileParser.parse(TocFileParser.java:45)
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.ui.workbench".
!STACK 0
java.lang.NegativeArraySizeException
	at org.eclipse.swt.widgets.Menu.getItems(Menu.java:855)
!MESSAGE Application error
!STACK 1
