Forum Topic - 20090305 can't open some projects: (7 Items)
There are some project I can't open.  I get a pop-up that says.  An internal error occured during: "Initialize Indexing"
.  java.lang.NullPointerException.
I attached the log file
Attachment: Text .log 23.92 KB
Re: 20090305 can't open some projects
Indexing".  java.lang.NullPointerException.
> http://community.qnx.com/sf/go/post23782
Did you somehow touch $(QNX_HOST)/etc/qcc directory? Can you archive it
and send it to me?
Not that I'm aware of.  I ge theproblem on both Windows and Linux so I doubt I would have done it on two machines by
mistake.
> Can you archive it  and send it to me?
While trying to create a scaled down version of the project I realized all it needed was the .project and .cproject for
the problem to show up. The problem happen on projects that I converted to C/C++ project about a month ago.  All the
other projects that were created as C/C++ are ok.
Attachment: Text project.tgz 1.29 KB
This project seems to me corrupted. There is no toolchain defined. The
same happens if I try to open it using build I20090221. How did you get it?
It is easy to fix. Create new empty one with desired attributes, then
copy all stuff but '.'-started files, and here you go.
mistake.
for the problem to show up. The problem happen on projects that I converted to C/C++ project about a month ago.  All the
> http://community.qnx.com/sf/go/post23793
I assume the .cproject got corrupted following svn update/commit.  I have some project that are ok, others that are
screwed up.  Yet they are all branches of the same trunk ;-(  Big mess.
Not sure how that helps, can't really create a new project to import stuff in, have about 100 make target defined.
Don't really feel like going through that...
At the moment i'm comparing .cproject to figure out if I can fix it.
>  I would have done it on two machines by mistake.
> it needed was the .project and .cproject for the problem to show up. The
> .  All the other projects that were created as C/C++ are ok.
> > General
Are you still using I20090305? I believe that recently the problem was
found and fixed. Stay tuned on the Foundry27 downloads:-)
Alex
>>> General
> http://community.qnx.com/sf/go/post25479
RE: 20090305 can't open some projects
> From: Alex Chapiro [mailto:community-noreply@qnx.com]
> Sent: March-27-09 4:59 PM
> To: general-ide
> Subject: Re: 20090305 can't open some projects
Yes 20090305.  I managed to manually fix the .cproject wasn`t pretty, and I had no idea what I was doing ;-)
> Alex
> The
> get it?
> have some project that are ok, others that are screwed up.  Yet they
> then
> stuff in, have about 100 make target defined.  Don't really feel like
> so I doubt
> realized all
> The
> month ago
> >>> General
> > General
> http://community.qnx.com/sf/go/post25484
