Forum Topic - Create Project failure?: (8 Items)
This is with a recent download...
Version: 4.6.0
Build id: I20090205
Create New C Project
Standard Makefile
QCC toolchain
and I get a null pointer exception message.
Attached is the last message in my .log
cburgess@qnx.com
Attachment: Text log.txt 10.46 KB
Re: Create Project failure?
> Version: 4.6.0
> Build id: I20090205
> Standard Makefile
> QCC toolchain
Can you try daily build version?
Yes, if you can tell me where to find it.. :-)
>> Version: 4.6.0
>> Build id: I20090205
>> Standard Makefile
>> QCC toolchain
> http://community.qnx.com/sf/go/post23475
cburgess@qnx.com
I tried the daily build and I get the same error
>> Version: 4.6.0
>> Build id: I20090205
>> Standard Makefile
>> QCC toolchain
cburgess@qnx.com
>>> Version: 4.6.0
>>> Build id: I20090205
>>> Standard Makefile
>>> QCC toolchain
>> General
OK, can you give me your conf directory?
Where is the conf dir?  You mean my .metadata?
>>>> Version: 4.6.0
>>>> Build id: I20090205
>>>> Standard Makefile
>>>> QCC toolchain
>>> General
> http://community.qnx.com/sf/go/post23481
cburgess@qnx.com
You have 6.4 base install? Did you define QNX_HOST and other env vars?
>>> Version: 4.6.0
>>> Build id: I20090205
>>> Standard Makefile
>>> QCC toolchain
>> General
Yes, I have stock 6.4.0 installed.  Building works just fine.  If I don't select the QCC toolchain then it
(rather OTHER) then it works fine.
>>>> Version: 4.6.0
>>>> Build id: I20090205
>>>> Standard Makefile
>>>> QCC toolchain
>>> General
> http://community.qnx.com/sf/go/post23482
cburgess@qnx.com
