03/02/2009 4:27 PM
post23280
IDE uses a "links" file to locate the Momentics help plugins. You can
verify below two setups to make sure the link to help is correct:
1) In the IDE - I assume you are using version 4.5.0 bundled in
Momentics 6.4.0, select Windows -> Preferences -> QNX, make sure the
current install is set up Momentics 6.4.0, if not, switch to it using
this IDE interface and restart.
2) In the IDE, select Help -> Software Updates -> Manage Configuration,
make sure a configuration site pointing to your
<QNX640_Install_Dir>/target/qnx6/usr/help/eclipse, and make sure this
site is enabled.
From: Kevin Stallard [mailto:community-noreply@qnx.com]
Sent: Monday, March 02, 2009 4:14 PM
To: general-ide
Subject: IDE 4.5 Help System
The help system in the IDE has been working fine until just recently.
The Documentation Roadmap link is now broken. I'm not entirely sure
what I did.
I used qwincfg.exe to switch to QNX .6.3.2 at one point, I thought this
might have been it as I found a post that indicated a directory to
delete. Followed those directions to no avail. I switched back to
6.4.0, but still no help.
Any recomendations?
Kevin
General
http://community.qnx.com/sf/go/post23279
