Forum Topic - make command not executing archiver (ntoppc-ar) in qde 4.5.1 Build id: I20081125: (11 Items)
I seem to have an error on compile of one of my projects when trying to link against a static library.  the make command
 on a normal commandline succeeds and I noticed that the crucial step of creating the static library archive was skipped
 by the IDE.  Specifically the ntoppc-ar line.  Is there a setting or environment variable that I am missing?
Thanks in advance for all your help.
Liam
Re: make command not executing archiver (ntoppc-ar) in qde 4.5.1 Build id: I20081125
You have two  project one static library project and one another and 2nd
trying to link
against first?
What types of projects are they? Can you post build output?
Liam Howlett wrote:
> Hello,
command on a normal commandline succeeds and I noticed that the crucial step of creating the static library archive was
skipped by the IDE.  Specifically the ntoppc-ar line.  Is there a setting or environment variable that I am missing?
> Liam
> http://community.qnx.com/sf/go/post23211
The project is c++ with an unmanaged make build on linux
in the IDE:
/opt/qnx632/host/linux/x86/usr/bin/qcc -V3.3.5,gcc_ntoppc -c -O -Wc,-mno-fp-moves -Wc,-Wall -Wc,-Wno-parentheses   -Wc,-
msoft-float -Wp,-MD,ppc.d -DTRACE_CODE  -DCOMMON_PLATFORM_CPLD_V1 -DSWLOG_NO_STACKTRACE -fstack-check  -
DTOGGLING_LED_BUG -DBSD=199307   -DTRACE_CODE  -DCOMMON_PLATFORM_CPLD_V1 -DSWLOG_NO_STACKTRACE -fstack-check  -
DTOGGLING_LED_BUG -DBSD=199307   -DNDEBUG -g     -I. -I/home/liam/comm200/commonRblBspStartupLib630/comm200/ppc/a-be -I/
home/liam/comm200/commonRblBspStartupLib630/comm200/ppc -I/home/liam/comm200/commonRblBspStartupLib630/comm200 -I/home/
liam/comm200/commonRblBspStartupLib630/lib/ppc/a.a-be -I/home/liam/comm200/commonRblBspStartupLib630/lib/ppc -I/home/
liam/comm200/commonRblBspStartupLib630/lib -I/home/liam/comm200/commonRblBspStartupLib630/common/include -I/home/liam/
comm200/commonRblBspStartupLib630/common/include/ppc -I/home/liam/comm200/commonRblBspStartupLib630/lps/include -I/home/
liam/comm200/commonRblBspStartupLib630/include -I/opt/qnx632/target/qnx6/usr/include      -EB     -DVARIANT_a -
DVARIANT_be  /home/liam/comm200/commonRblBspStartupLib630/comm200/main.c
make[5]: Leaving directory `/home/liam/comm200/commonRblBspStartupLib630/comm200/ppc/a-be'
make[4]: Leaving directory `/home/liam/comm200/commonRblBspStartupLib630/comm200/ppc'
make[3]: Leaving directory `/home/liam/comm200/commonRblBspStartupLib630/comm200'
make -Ccommon install
make[3]: Entering directory `/home/liam/comm200/commonRblBspStartupLib630/common'
make -j 1 -Cppc -fMakefile install
make[4]: Entering directory `/home/liam/comm200/commonRblBspStartupLib630/common/ppc'
make -j 1 -Cbe -fMakefile install
on the command line:
/opt/qnx632/host/linux/x86/usr/bin/qcc -V3.3.5,gcc_ntoppc -c  -Wc,-mno-fp-moves -Wc,-Wall -Wc,-Wno-parentheses   -Wc,-
msoft-float -DTRACE_CODE  -DCOMMON_PLATFORM_CPLD_V1 -DSWLOG_NO_STACKTRACE -fstack-check  -DTOGGLING_LED_BUG -DBSD=199307
   -DTRACE_CODE  -DCOMMON_PLATFORM_CPLD_V1 -DSWLOG_NO_STACKTRACE -fstack-check  -DTOGGLING_LED_BUG -DBSD=199307 -DNULL -
DCOMM200 -DDOC_PRESENT -DNULL -DPCI_PRESENT -DNULL -DUART0 -DNULL -DNDEBUG     -I. -I/home/liam/comm200/
ppc405epRblBspPro/comm200/ppc/a-be -I/home/liam/comm200/ppc405epRblBspPro/comm200/ppc -I/home/liam/comm200/
ppc405epRblBspPro/comm200 -I/home/liam/comm200/ppc405epRblBspPro/lib/ppc/a.a-be -I/home/liam/comm200/ppc405epRblBspPro/
lib/ppc -I/home/liam/comm200/ppc405epRblBspPro/lib -I/home/liam/comm200/ppc405epRblBspPro/common/include -I/home/liam/
comm200/ppc405epRblBspPro/comm200/include -I/home/liam/comm200/ppc405epRblBspPro/include -I/opt/qnx632/target/qnx6/usr/
include      -EB     -DVARIANT_a -DVARIANT_be  /home/liam/comm200/ppc405epRblBspPro/comm200/pci.c
/bin/rm -f  /home/liam/comm200/ppc405epRblBspPro/comm200/ppc/a-be/libipl-ppc.a
/opt/qnx632/host/linux/x86/usr/bin/ntoppc-ar -r  /home/liam/comm200/ppc405epRblBspPro/comm200/ppc/a-be/libipl-ppc.a eth.
o gpio.o ioLib.o leds.o main.o pci.o
make[5]: Leaving directory `/home/liam/comm200/ppc405epRblBspPro/comm200/ppc/a-be'
make[4]: Leaving directory `/home/liam/comm200/ppc405epRblBspPro/comm200/ppc'
make[3]: Leaving directory `/home/liam/comm200/ppc405epRblBspPro/comm200'
done.
Making common...         ...
If it just make project IDE just launches make. The only difference can
be in targets,
what make target IDE uses when you run it? (Also can be env vars, but
this is only if you run make -e)
> in the IDE:
,-msoft-float -Wp,-MD,ppc.d -DTRACE_CODE  -DCOMMON_PLATFORM_CPLD_V1 -DSWLOG_NO_STACKTRACE -fstack-check  -
eth.o gpio.o ioLib.o leds.o main.o pci.o
> make[3]: Leaving directory...
Well,
They both "make load".
There are some variables I set.. EXCLUDE_VARIANTLIST=g and such, but I have set them in the IDE as Environment variables
.  Also, these should be fine as it would fail a different way.
Is there anything else that could cause ntoppc-ar to not be used? some tool configuration or anything?
Make does not use env variables as "make variables" by default (if make
sets them  env do not have precedence). You need to add flag -e to make
to use them. Or just edit make command
to
make EXCLUDE_VARIANTLIST=g
in the project properties
Liam Howlett wrote:
> Well,
variables.  Also, these should be fine as it would fail a different way.
> http://community.qnx.com/sf/go/post23238
I tried that suggestion but it still failed.
I seem to have it working using the gnu toolchain instead of the QNX toolchain, although some warnings are showing up as
 errors.
Is there a place to turn down the strictness?
Liam
> , although some warnings are showing up as errors.
> Thanks,
> Liam
Specifically the error in question is many like the following:
"/opt/qnx632/target/qnx6/usr/include/c++/3.3.5/bits/localefwd.h macro "toupper" passed 2 arguments, but takes just 1"
These are due to using c in a c++ project, I'd like to stop this from being detected as an error.
In this thread I found console output but not make file itself. Is it a
problem  for you to send a small project as an example of what you are
trying to do? Iwould really appreciate that.
Alex
as errors.
> Thanks,
> Liam
> http://community.qnx.com/sf/go/post23283
Our build is a combination of scripts and make files, I was just hoping for a simple answer for a setting.  Apparently
the build was setup to support make from an older QNX that didn't do dependencies correctly (I'm not sure on the details
 as it was before my time).. but the short answer is that I don't know enough about the scripts to create a new project
to show what is going on and I don't think I'm allowed to send it out as it is.
Oddly enough, one of my coworkers managed to build the same project without these issues using the QNX toolchain, so I'm
 pretty sure it's something in my environment that caused the error that was fixed by switching toolchains.
Now I'd just like a way to turn down the error reporting, as the build succeeds with warnings on the commandline but the
 project in the IDE reports these warnings as errors.
IDE does not convert any warning to errors. It just runs make. You have different environment/toolchain when you running
 command line vs IDE.
details as it was before my time).. but the short answer is that I don't know enough about the scripts to create a new
project to show what is going on and I don't think I'm allowed to send it out as it is.
I'm pretty sure it's something in my environment that caused the error that was fixed by switching toolchains.
the project in the IDE reports these warnings as errors.
> http://community.qnx.com/sf/go/post23355
