Forum Topic - qconfig under Linux: (8 Items)
qconfig under Linux
Aside the eval 'qconfig...' trick, is there anything more user friendly to change version and to make it permanent.
Under Windows I can use the IDE 4.5.0 but still use gcc 3.3.5, but under Eclipse I use qconfig to use 6.3.2 but when I
invoke qde ( even if I specify the path of 6.4.0's qde ) it seems to use the 6.3.2 IDE ( as show by the splash screen ).
Is it normal that QDE doesn't show up in any menu.  I have to open a terminal and start QDE from there.
Re: qconfig under Linux
Assuming I understand you question correctly:
On Linux you set 4 environment variables (plus PATH is needed) that IDE needs, in your .profile and when you run qde it
will use them to pick between 6.3.2 and 6.4.
If you want a menu you have to create it manually (Applications->Add/Remove...), it depends on your system (installer
does not create one for Ubuntu for example).
Or you can create script qde640 (by copying qde script from QNX_HOST/bin and adding those env vars)
- which always would run qde pointing to 640 installation. See env vars on wiki FAQ
http://community.qnx.com/sf/wiki/do/viewPage/projects.ide/wiki/IDEGeneralFAQ
> http://community.qnx.com/sf/go/post22381
RE: qconfig under Linux
> Sent: February-17-09 2:54 PM
> To: general-ide
> Subject: Re: qconfig under Linux
> needs, in your .profile and when you run qde it will use them to pick
> >Add/Remove...), it depends on your system (installer does not create
Ok
> on wiki FAQ
> alFAQ
Ok thanks. Coming from  Windows I was looking at something similar to qwincfg.exe
I will rephrase the question that didn't get answered.
On windows I always start QDE from 4.5 (in the Start Menu) and the version is confirm by the splash screen, even if I
previously use qwincfg.exe to point to 6.3.2.  That tells me I'm using the latest IDE from 6.4.0 but the all the build
tools of 6.3.2.  On Linux I set the environment variable to point to 6.3.2, except QNX_JAVAHOME which still point to the
 640 directory. I start qde, but that give me the 4.0.1 IDE.  I try to use the IDE from 6.4.0 by typing /opt/qnx640/....
/qde but no difference.    How can I use the 4.5.0 IDE but the 6.3.2 build tools.
> under Eclipse I use qconfig to use 6.3.2 but when I invoke qde ( even
> > General
> http://community.qnx.com/sf/go/post22383
If you run just qde it picks it from the PATH
if you run it from /opt/qnx640/host/linux/x86/usr/bin/qde it will bring IDE from QNX_HOST again.
So either modify the script to set QNX_HOST in there as I recommended or create another script that does it.
#!/bin/sh
QNX_VER=qnx630
MAKEFLAGS=-I/opt/$QNX_VER/target/qnx6/usr/include
QNX_CONFIGURATION=/etc/qnx
QNX_HOST=/opt/$QNX_VER/host/linux/x86
QNX_JAVAHOME=/opt/$QNX_VER/_jvm
QNX_TARGET=/opt/$QNX_VER/target/qnx6
p1=`echo $PATH | sed -e "s?$QNX_HOST/usr/bin:??" -e "s?/etc/qnx/bin:??"`
PATH=$QNX_HOST/usr/bin:$p1
export MAKEFLAGS
export QNX_HOST
export QNX_TARGET
export QNX_CONFIGURATION
export LD_LIBRARY_PATH=$QNX_HOST/usr/lib:$LD_LIBRARY_PATH
/opt/qnx640/host/linux/x86/usr/qde/eclipse/qde "$@"  #runs IDE 4.5 targeting 6.3.2
>> -----Original Message-----
>> To: general-ide
> Ok
>> on wiki FAQ
>> alFAQ
>>> General
>> General
> http://community.qnx.com/sf/go/post22389
That works, but I must be missing something because with 4.6.0 and start qde directly from there I do get 4.6.0 and not
4.0.1. Oh well, I now created three scripts, qde400 qde450 and qde460.  Everything's peachy.
Thanks Elena!
> Sent: February-17-09 4:04 PM
> To: general-ide
> #!/bin/sh
> QNX_VER=qnx630
> export MAKEFLAGS
> export QNX_HOST
> export QNX_TARGET
> targeting 6.3.2
> >> To: general-ide
> IDE
> pick
> create
> > Ok
> vars
> >> on wiki FAQ
> >> alFAQ
> qwincfg.exe
> version is confirm by the splash screen, even if I previously use
> from 6.4.0 but the all the build tools of 6.3.2.  On Linux I set the
> point to the 640 directory. I start qde, but that give me the 4.0.1
> IDE.  I try to use the IDE from 6.4.0 by typing /opt/qnx640/..../qde
> tools.
> even
> >>> Is it normal that QDE...
Because with 4.6.0 you running "qde" binary not script. Script is generated by installer.
not 4.0.1. Oh well, I now created three scripts, qde400 qde450 and qde460.  Everything's peachy.
> Thanks Elena!
>> To: general-ide
>> #!/bin/sh
>> QNX_VER=qnx630
>> export MAKEFLAGS
>> export QNX_HOST
>> export QNX_TARGET
>> targeting 6.3.2
>>>> To: general-ide
>> IDE
>> pick
>> create
>>> Ok
>> vars
>>>> on wiki FAQ
>>>> alFAQ
>> qwincfg.exe
>> tools.
>>>> friendly to change version and to make it...
Re: qconfig under Windows
In order to have multiple instances of the IDE, each configured using a different version of the toolset ( 6.3.2, 6.4.0)
, i have been using shorcuts with qconfig -e  ... -r ...  However this create a text window into which qconfig runs.
Not a real issue but is there a way of getting rid of this.
Would be nice if the installer could create menu-item for the various tool set already present on the machine.
RE: qconfig under Windows
You could try using "start qde" as the command rather than just qde (or
what ever you use).
