AW: Problem with App Profiler importing kev file using funtion instrumenation
02/12/2009 9:59 AM
post22094
I've put the jar to my plugin folder and deactivated the old one (com.qnx.tools.ide.profiler2.core_4.6.0.v200902052000.
jar) by renaming it.
After restarting I checked the plugin veriosn in Help/About/Plug-in Details
it shows the right (new one) version.
Unfortunately it has not changed, the error window is popping up and exception shown in .log file is the same.
!ENTRY com.qnx.tools.ide.profiler2.ui 4 4 2009-02-12 15:53:20.080
!MESSAGE 58
!STACK 0
java.lang.ArrayIndexOutOfBoundsException: 58
at com.qnx.tools.ide.profiler2.core.input.fitrace.DbImporter.setLastExit(DbImporter.java:284)
at com.qnx.tools.ide.profiler2.core.input.fitrace.DbImporter.processExit(DbImporter.java:197)
at com.qnx.tools.ide.profiler2.core.input.fitrace.DbImporter.record(DbImporter.java:105)
at com.qnx.tools.ide.profiler2.core.input.kev.KevImporter.processEvent(KevImporter.java:304)
at com.qnx.tools.ide.profiler2.core.input.kev.KevImporter.importKev(KevImporter.java:238)
at com.qnx.tools.ide.profiler2.core.input.kev.KevImporter.run(KevImporter.java:164)
at com.qnx.tools.ide.profiler2.core.input.ProfilerImportHandler.run(ProfilerImportHandler.java:109)
at com.qnx.tools.ide.profiler2.ui.actions.ImportRawAction.run(ImportRawAction.java:55)
at com.qnx.tools.ide.profiler2.ui.actions.UiRunnableDelegate$1.run(UiRunnableDelegate.java:37)
upload is still running, you should order more bandwidth ....
/hp
>Von: Elena Laskavaia [mailto:community-noreply@qnx.com]
>Gesendet: Donnerstag, 12. Februar 2009 15:46
>An: general-ide
>Betreff: Re: Problem with App Profiler importing kev file
>I think I found the problem, try this patch (if you using IDE
>4.6 20090205) save this file in
>plugins/com.qnx.tools.ide.profiler2.core_4.6.0.200902120943.jar
> of installation
>General
>http://community.qnx.com/sf/go/post22089
