Forum Topic - Help Server Option: (4 Items)
Help Server Option
I want to use IDE 4.5 help from remote host. But after every restart http server starts on new random port. In 4.0 there
 were Help Server Option in Preferences..in 4.5 it's absent.
How can I setup fixed port number in 4.5 Bundle?
Re: Help Server Option
I think that you can use customization plugin
com.qnx.tools.ide.momentics and in plugin-customization.ini file add line
org.eclipse.help.appserver/port=.....
See
http://help.eclipse.org/help32/index.jsp?topic=/org.eclipse.platform.doc.isv/guide/ua_help_setup_infocenter.htm
Actually I didn't try it myself:-)
On 06/02/2009 4:50 AM, mike ko wrote:
there were Help Server Option in Preferences..in 4.5 it's absent.
> http://community.qnx.com/sf/go/post21572
You can start eclipse infocenter without actual IDE from command line:
cd <IDE installation folder, parent of eclipse folder>
cp eclipse/qde eclipse/eclipse #this needed because otherwise tool would not recognize installation folder
java -cp eclipse/plugins/org.eclipse.help.base_3.3.1.v20070813_33x.jar:eclipse/plugins/org.mortbay.jetty_5.1.11.
v200706111724.jar org.eclipse.help.standalone.Infocenter -command start -eclipsehome eclipse/ -port 7000 -vmargs -
Xmx512M
To access it:
http://localhost:7000/help/index.jsp  (assuming you run on 7000)
mike ko wrote:
Thanks! Eclipse Infocenter works fine for me.
