Re: Malloc Information View
02/06/2009 9:24 AM
post21588
I tried running binary compiled with 6.3.2 on 6.4 and it works for me... Can you try some simple app on your target to
see if you get same results?
If you do send it (binary) to me (attach to the forum).
Mario Charest wrote:
>> -----Original Message-----
>> From: Elena Laskavaia [mailto:community-noreply@qnx.com]
>> Sent: February-05-09 2:58 PM
>> To: general-ide
>> Subject: Re: Malloc Information View
>> It does load libc.so.3... Weird (that it does not work). Try my
>> workaround with
>> QCONN_ALT_MALLOC=libc.so.3 qconn
> Still no difference.
> Don't have md5 handy ( not working with Linux ). But I`m sure I`m using the one you indicated in the link.
>>>> Can you please look at Malloc Information what library are loaded by
>>>> what name? (You showed me ldd which is not the same)
>>> I don't understand what you mean. I took a guess, check the attached
>> file.
>>>>> I'm confused, according to the name that seems to be a qconn for
>>>> 6.3.2, is that what I should be using on 6.4.0 system?
>>>>> At any rated, tried it, no difference.
>>>>>> Sent: February-05-09 2:37 PM
>>>>>> To: general-ide
>> http://community.qnx.com/sf/frs/do/downloadFile/projects.ide/frs.ide_in
>>>>>> tegration_builds.momentics_632_patch_for_profiler/frs1426?dl=1
>>>>>> it is update from 4th December.
>>>>>>> Can't find the updated qconn you're talking about.
>>>>>>>> Sent: February-05-09 2:26 PM
>>>>>>>> To: general-ide
>>>>>>>> Could be. Try updated latest qconn patch (we had a fix post
>> 6.4).
>>>>>> Does
>>>>>>>> you binary shows that it loads libqnx.so? (From Memory
>> Information
>>>>>>>> view)?
>>>>>>>>> The malloc information view shows faulty information when it's
>> a
>>>>>>>> program build on 6.3.2 but running on 6.4.0.
>>>>>>>>> Could it be related to location/offset of _malloc_stat, not
>> being
>>>>>> the
>>>>>>>> same in the libc.so.2 of 6.4.0 then of 6.3.2?
>>>>>>>>> See attachement.
>>>>>>>>> _______________________________________________
>>>>>>>>> General
>>>>>>>>> http://community.qnx.com/sf/go/post21508
