Forum Topic - Profiling: (8 Items)
Profiling
I'm playing around with profiling.  I got 6.4.0 IDE under windows configure for 6.3.2. I create a new C++ project that I
 configured to use gcc 3.3.5 and I specify as a build options "Build for Profiling (Call Count Instrumentation)".
I manually start the executable but can't find the gmon.out file anywhere. That the first problem ( could be something I
 missed configure ). The second problem is if I select "Build for Profiling (Functions Instrumentation)" I get a problem
 at link time "cannot find -lprofilingS". My guess is this option should not be present if the compiler is 3.3.5 as it's
 not supported.
Re: Profiling
 I configured to use gcc 3.3.5 and I specify as a build options "Build for Profiling (Call Count Instrumentation)".
 I missed configure ).
If you start it from command line you need to specify some env variables to enable it, it should be in doc.
http://www.qnx.com/developers/docs/6.3.2/ide_en/user_guide/profiler.html#profile_postmortem
> The second problem is if I select "Build for Profiling (Functions Instrumentation)" I get a problem at link time "
cannot find -lprofilingS". My guess is this option should not be present if the compiler is 3.3.5 as it's not supported.
It is not about compiler. You need profiler patch for 6.3.2, which you need to install on host (see 4.5 instructions
page on wiki). It does work with 6.3.2.
http://community.qnx.com/sf/wiki/do/viewPage/projects.ide/wiki/Builds_Tau_Integration (Before you install IDE section)
> http://community.qnx.com/sf/go/post20425
RE: Profiling
> configure for 6.3.2. I create a new C++ project that I configured to
> anywhere. That the first problem ( could be something I missed
> configure ).
Found my problem, need to run as root, running with +s flag is not enough.
> Instrumentation)" I get a problem at link time "cannot find -
> need to install on host (see 4.5 instructions page on wiki). It does
> work with 6.3.2.
Ok thanks.
> > General
> http://community.qnx.com/sf/go/post20429
Re: RE: Profiling
The problem is was QCONN_PROFILER must not be set for gmon.out to be created
Re: Profiling
yes this one would redirect it to IDE. You need to set PROFDIR instead.
> http://community.qnx.com/sf/go/post20437
Re: Profiling
I'm a QNX newbie, and after wrestling for a huge amount of time attempting to build all our dependencies with the IDE, I
 had a lot more luck directly building under native neutrino with command-line GNU "./configure; make..." etc.
However, now I need to profile my code, and I guess the only way is to insert my own traceevent()s throughout.
(traceparser?? traceprinter??)
Is there a simple example that takes things all the way from the user code, through traceparse(), etc for user-level
code?  At some point soon it will have to marry up to a BSP, and presumably new devices and drivers, at which point
(hopefully!) I can get my user-level trace events with the new kernel stuff...
thanks in advance!
Chris
AW: Profiling
If you want to do full application profiling, just take a look at "Application Profiler" which is *not* gprof
take a look at function instrumentation
http://community.qnx.com/sf/wiki/do/viewPage/projects.ide/wiki/IDE4.5ApplicationProfilerTrial
to use TraceEvent() and traceparser() just go to "System Analysis Toolkit"
http://www.qnx.com/developers/docs/6.4.0/instr_en/instr/functions.html
to use your own TraceEvent() in your code just use one of the three basic ones
   TraceEvent(_NTO_TRACE_INSERTSUSEREVENT,  1, int_1, int_2);
   TraceEvent(_NTO_TRACE_INSERTUSRSTREVENT, 2, "your message");
   TraceEvent(_NTO_TRACE_INSERTCUSEREVENT,  3, intArray, numInts);
I'm assuming that you work on traceparser source ...
you will have to register your event callback handler either for a range
or for single events, in this example it is done for a range using the given macros
   TP_CSR(traceparser_cs_range(tp_state, NULL, usr_ev, _NTO_TRACE_USER, _NTO_TRACE_USERFIRST, _NTO_TRACE_USERLAST));
your callback function has to look like this:
static int usr_ev(tp_state_t tp_state, void* d, unsigned h, unsigned t, unsigned* p, unsigned l) {
   // switch over your handled user evnet ids
   switch (_NTO_TRACE_GETEVENT(h)) {
      case 33 : // your event ids here
         (void) fprintf
         g_out_stream,
         "t:0x%08x CPU:%02d USREVENT:EVENT:%d TYPE:MALLOC IP:0x%08x SIZE:%08d PTR:0x%08x\n",
         t,
         _NTO_TRACE_GETCPU(h),
         _NTO_TRACE_GETEVENT(h),
         CS32(p[0]),
         CS32(p[1]),
         CS32(p[2])
         return (0);
HTH
/hp
>Von: Chris Nicholas [mailto:community-noreply@qnx.com]
>Gesendet: Samstag, 7. Februar 2009 00:31
>An: general-ide
>Betreff: Re: Profiling
>throughout.(traceparser?? traceprinter??)
>the user code, through traceparse(), etc for user-level code?
>kernel stuff...
>thanks in advance!
>Chris
>General
>http://community.qnx.com/sf/go/post21690
Re: AW: Profiling
Actually .. even easier is to start using the trace_* functions put in
in 6.4.0 that make this insertion a little bit more
straightforward:
http://sendreceivereply.wordpress.com/2009/02/07/making-tracing-even-easier/
Thomas
