Forum Topic - Target File System Navitagor: (4 Items)
When performing file copy via the Target File System Navitor over a slow link the whole IDE becomes unresponsive.  Hence
 if the file takes 1 minute to copy, can`t use the IDE for 1 minute.
Re: Target File System Navitagor
Thanks for reporting. Bug #64545 (IDE becomes unresponsive when copying file using Target File System Navigator) is
created.
Btw which direction you copy and which method you use? I.e. drag and drop, menu commands etc?
RE: Target File System Navitagor
It`s a drag and drop from C/C++ Project view to the target.  Haven't tried anything else.  When the link is fast the
problem doesn't show up because the copy takes only a fraction of a second.  I noticed the situation when working from
home and copying a file over internet to a target at the office.
> Sent: January-13-09 10:31 AM
> To: general-ide
> Subject: Re: Target File System Navitagor
> http://community.qnx.com/sf/go/post19965
