Re: Problem upgrading project
01/05/2009 1:30 PM
post19386
If you are using external builder, it uses Makefile and environment in
order to build the project. Makefile does not depend on .cproject
content (this is your creature).Environment matters if your makefile
uses predefined macros such as CC, CCFLAGS etc., and it is generated
using information about configuration, stored in .cproject. But you can
verify environment looking to the project properties, cannot you?
On 05/01/2009 1:10 PM, Mario Charest wrote:
>> -----Original Message-----
>> From: Alex Chapiro [mailto:community-noreply@qnx.com]
>> Sent: January-05-09 12:43 PM
>> To: general-ide
>> Subject: Re: Problem upgrading project
>> Could you please send your makefile. If you can send unconverted
>> project, it would be even better. As to the reported problem, it is not
>> surprise for me. Some work should be done to clean up all around
>> regular
>> make projects.
> Not sure why you need the makefile. I can send you the .cproject file just as the project is first open and the the .
cproject after I do the dummy change to the project's settings.
> I thing the real bug is that the Project Settings will show the GNU Compiler Collection to be 4.2.4 even though it's
set to 3.3.5 in the .cproject file.
>> On 05/01/2009 12:10 PM, Mario Charest wrote:
>>> The project is from 6.3.2. On a machine with only 6.4.0 on it I
>> obtain the project from SVN. I then edited our custom makefile to use
>> 4.2.4 instead of -3.3.5. When I tried to build it qcc complain that it
>> could find 4.2.4.
>>> I check the project's setting it was showing TargetOS to be QNX6,
>> Target CPUU to be X86 - Little Endian, Compierl GNU Compiler Collection
>> 4.2.4 and run time to be default. Everything was looking ok.
>>> It's only when I changed the target CPU to arm and then back to X86
>> that is started working. It seems the .cproject file got updated with
>> the proper setting only when I made a change to the project.
>>> This is reproducible at will.
>>> General
>>> http://community.qnx.com/sf/go/post19367
>> General
>> http://community.qnx.com/sf/go/post19371
> http://community.qnx.com/sf/go/post19379
