RE: SCM and .cproject strategies
12/23/2008 9:41 AM
post19178
> Sent: December-23-08 9:26 AM
> To: general-ide
> Subject: Re: SCM and .cproject strategies
> I am not sure what you mean. These are text file and updated the same
> way as other files. Just don't let it merge in file.
Say I added make target to the project and somebody else also added a make target and he committed his changed. Then I
do the update, close the project and then open it again, the project seems to be corrupted. Although I can see the
make target I can`t run them.
The "just don`t let it merge in file" is was I was afraid I would get as an answer. I mean it`s the kind of thing that
can`t be asked to user. It will happen, somebody is going to forget to not do it. It`s also not documented. Since we
started using Eclipse I`v had lots of people coming to me for support trying to understand what was going on. It`s only
recently that we`ve discover what is going on.
> To see actual files (if you need to sync, revert, update) you can open
> Navigator view.
> Mario Charest wrote:
> > When doing Team/Update (svn) turn the .cproject into a file the IDE
> can't process resulting in hard to diagnose problem.
> > I've found the process of doing an update on a project stressful
> because I'm not sure what is going to happen to the .settings
> directory, .cproject and .project files. I"ve look for some
> documentation on how to proceed but couldn't find any.
> > General
> > http://community.qnx.com/sf/go/post19138
> http://community.qnx.com/sf/go/post19176
