Forum Topic - Info required about building OS and Flash Images: (3 Items)
I am using QNX Momentics IDE in windows xp and Neutrino in VMWARE.
I need to build and load a QNX OS image on compact flash, since i have not done these kind of things i would like to
clarify some points before starting.
1) While creating new QNX System Builder Project there is an option for selecting build file "Import Existing Buildfile"
, in which i need to know where can i find the buildfile?
2) Where can i provide the base address of the target while building?Is it in IPL?
3) If i want to move this image to Neutrino in VMWARE, can i use the USB flash card reader?
Thakns in advance for helping.
Regards
Sreesha
Re: Info required about building OS and Flash Images
On 21/12/2008 9:17 PM, Sreesha AG wrote:
Buildfile", in which i need to know where can i find the buildfile?
You should know that :-)
flash card reader?
I don't know about USB flash (i guess you cannot). IDE provides loading
image to the target using serial terminal and using network via TFTP
protocol. It depends on your board: 0x1f0000nitor, which protocol  does
it supports.
> Regards
> Sreesha
> http://community.qnx.com/sf/go/post19111
> selecting build file "Import Existing Buildfile", in which i need to know
What i want to know is, importing the existing build file means whether i have to import the  binaries of the project
which i have built or some other thing?I want to make that point clear.
