Forum Topic - Errors: mi_cmd_var_create: unable to create variable object: (5 Items)
I could not continue debugging when encounting this problem.
But this happens only in some particular section of my program, the gdb is okay in other sections.
appreciate your suggestions
Eric
Re: Errors: mi_cmd_var_create: unable to create variable object
> Eric
Hello Eric,
What versions of gdb and gcc are you using?
Is your project C or C++?
Do you have a small test case that demonstrates the problem?
Aleksandar
> > Eric
> Hello Eric,
GNU gdb 5.2.1qnx-nto;  GCC 2.95.3
QNX C++
Sorry, i have no clear clues when this happens
> Thanks,
> Aleksandar
I would suggest trying the latest gdb. It works as a drop-in
replacement and it should work better than gdb 5.2.1.
You can download the latest gdb from here:
http://community.qnx.com/sf/frs/do/listReleases/projects.toolchain/frs.gdb
thx, new version gbd worked fine till now.
