Forum Topic - 4.5 IDE Crash: (2 Items)
4.5 IDE Crash
Whenever I run the new 4.5 IDE it crashes and I get the following error from the log file.  I have tried reinstalling
but it has not fixed the issue.
!SESSION 2008-12-03 14:45:48.821 -----------------------------------------------
eclipse.buildId=I20080204
java.version=1.5.0_11
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
Command-line arguments:  -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.core.runtime 4 0 2008-12-03 14:45:49.413
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: The bundle could not be resolved. Reason: Missing Constraint: Require-Bundle: org.
eclipse.core.jobs; bundle-version="[3.2.0,4.0.0)"
	at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:305)
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:350)
	at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1118)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:634)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:508)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:282)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:468)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:195)
	at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:297)
!ENTRY org.eclipse.osgi 4 0 2008-12-03 14:45:49.413
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.core.runtime_3.3.100.v20070530.jar/ was not resolved.
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service. Ensure that the org.eclipse.core.runtime bundle
is resolved and started (see config.ini).
	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:72)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:363)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:176)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Unknown Source)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:508)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
!ENTRY org.eclipse.osgi 2 0 2008-12-03 14:45:49.429
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause
if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2008-12-03 14:45:49.429
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.core.runtime_3.3.100.v20070530.jar/ [3] was not resolved.
!SUBENTRY 2 org.eclipse.core.runtime 2 0 2008-12-03 14:45:49.429
!MESSAGE Missing Constraint: Require-Bundle: org.eclipse.core.jobs; bundle-version="[3.2.0,4.0.0)"
Any help would be great. Thanks.
Re: 4.5 IDE Crash
So did you try to remove configuration area (from previous post)?
> !MESSAGE
> !STACK 0
> !STACK 1
bundle is resolved and started (see config.ini).
cause if it exists:
> http://community.qnx.com/sf/go/post17888
