Forum Topic - 6.4 - 'Managed' dependency issue: (4 Items)
I have a managed project executable with a managed project static library.  I set the "Project References" for the
executable to the library (both in same workspace).
If I rebuild the library, I expect the executable to pick up the change and relink when I say 'build' of executable.
BUT the executable does not rebuild - instead I get "Nothing to build".
What else do I need to set to get correct 'make' behavior?
Re: 6.4 - 'Managed' dependency issue
The easiest thing you can do is to ad references to libraries projects
(see Properties-> Project references).
Alex
> http://community.qnx.com/sf/go/post15963
If you read my post, you will see I already set "project references" to the library project.
You are right. Managed project is not that smart to re-link it. We will look at it.
