Re: IDE managed build error
11/04/2008 2:53 PM
post15930
Thank you for the problem reporting. It has been addressed and will be
included into upcomeing integration build.
On 04/11/2008 1:41 PM, Kevin Stallard wrote:
> I went to individual files to add a -E option to extra options for the preprocessor. Once I did this, I started to
get the following:
> **** Rebuild of configuration Debug for project phcpp ****
> **** Internal Builder is used for build ****
> Build error
> org.eclipse.cdt.managedbuilder.internal.core.ResourceConfiguration
> Below is an excerpt from the IDE log about this error:
> !ENTRY org.eclipse.jface 4 2 2008-11-04 11:34:06.263
> !MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.jface".
> !STACK 0
> java.lang.ClassCastException: org.eclipse.cdt.managedbuilder.internal.core.ResourceConfiguration
> at com.qnx.tools.ide.qde.managedbuilder.core.QCCCommandLineGenerator$1.calculateTarget(QCCCommandLineGenerator.java:
39)
> at com.qnx.tools.ide.qde.managedbuilder.core.QCCCommandLineGenerator$1.getFlags(QCCCommandLineGenerator.java:73)
> at org.eclipse.cdt.managedbuilder.ui.properties.ToolSettingsPrefStore.getString(ToolSettingsPrefStore.java:161)
> at org.eclipse.cdt.ui.newui.MultiLineTextFieldEditor.doLoad(MultiLineTextFieldEditor.java:255)
> at org.eclipse.jface.preference.FieldEditor.load(FieldEditor.java:496)
> at org.eclipse.cdt.managedbuilder.ui.properties.BuildToolSettingUI.updateFields(BuildToolSettingUI.java:593)
> at org.eclipse.cdt.managedbuilder.ui.properties.BuildToolSettingUI.setValues(BuildToolSettingUI.java:599)
> at org.eclipse.cdt.managedbuilder.ui.properties.ToolSettingsTab.displayOptionsForTool(ToolSettingsTab.java:243)
> at org.eclipse.cdt.managedbuilder.ui.properties.ToolSettingsTab.handleOptionSelection(ToolSettingsTab.java:383)
> at org.eclipse.cdt.managedbuilder.ui.properties.ToolSettingsTab.updateData(ToolSettingsTab.java:596)
> at org.eclipse.cdt.managedbuilder.ui.properties.ToolSettingsTab.setVisible(ToolSettingsTab.java:273)
> at org.eclipse.cdt.ui.newui.AbstractCPropertyTab.handleTabEvent(AbstractCPropertyTab.java:507)
> at org.eclipse.cdt.ui.newui.AbstractPage.setVisible(AbstractPage.java:590)
> at org.eclipse.jface.preference.PreferenceDialog.showPage(PreferenceDialog.java:1278)
> at org.eclipse.ui.internal.dialogs.FilteredPreferenceDialog.showPage(FilteredPreferenceDialog.java:433)
> at org.eclipse.jface.preference.PreferenceDialog$9.selectionChanged(PreferenceDialog.java:698)
> at org.eclipse.jface.viewers.StructuredViewer$3.run(StructuredViewer.java:842)
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
> at org.eclipse.core.runtime.Platform.run(Platform.java:857)
> at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:46)
> at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:199)
> at org.eclipse.jface.viewers.StructuredViewer.firePostSelectionChanged(StructuredViewer.java:840)
> at org.eclipse.jface.viewers.StructuredViewer.setSelection(StructuredViewer.java:1642)
> at org.eclipse.jface.viewers.TreeViewer.setSelection(TreeViewer.java:1095)
> at org.eclipse.jface.preference.PreferenceDialog.selectSavedItem(PreferenceDialog.java:1009)
> at org.eclipse.ui.internal.dialogs.FilteredPreferenceDialog.selectSavedItem(FilteredPreferenceDialog.java:476)
> at org.eclipse.jface.preference.PreferenceDialog$4.run(PreferenceDialog.java:369)
> at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:67)
> at org.eclipse.jface.preference.PreferenceDialog.createContents(PreferenceDialog.java:365)
> at org.eclipse.jface.window.Window.create(Window.java:426)
> at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1081)
> at org.eclipse.ui.internal.dialogs.PropertyDialog.createDialogOn(PropertyDialog.java:81)
> at...
11/04/2008 4:10 PM
post15935
Integration build is posted, see http://community.qnx.com/sf/wiki/do/viewPage/projects.ide/wiki/WhatIsNewIn4.5.1
> I may have indicated a problem with this before, but thought I'd post information about my current woes as a data
point.
get the following:
> Build error
> !STACK 0
39)
> at...
