Forum Topic - Can't find librcheck.so: (15 Items)
I can't seem to do memory analysis as the system can't find (and neither can I) librcheck.so.
Can anyone point to where it should be and what I can do to find it?
Kevin
Re: Can't find librcheck.so
The error I get when trying to start memory analysis for a process is:
"Could not preload library librcheck.so"
This is new library that bundled with 6.4.0. If you running on 6.3.2 target you have to manually install it (or include
in the image).
Patch available on foundry27 http://community.qnx.com/sf/frs/do/downloadFile/projects.ide/frs.ide_integration_builds.
momentics_632_patch_for_profiler/frs1427?dl=1
Got it...thanks
Kevin
> you have to manually install it (or include in the image).
> projects.ide/frs.ide_integration_builds.momentics_632_patch_for_profiler/
> frs1427?dl=1
Stealing this thread.
But libcheckr.so needs libc.so.3 which isn't included in 6.3.2. Does that mean libc.so.3 also need to be copied.
I copied it but things aren't peachy.  When I launch a program it sigsegv right away, before main(), in
_block_mem_malloc_align.
You would need to replace libc.so.3 AND libc.so.2 and also redirect /usr/lib/ldqnx.so.2 to point to libc.so.3
and as an aside - it's not supported :-)
>> frs1427?dl=1
> http://community.qnx.com/sf/go/post25605
cburgess@qnx.com
RE: Can't find librcheck.so
> From: Colin Burgess [mailto:community-noreply@qnx.com]
> Sent: March-30-09 4:26 PM
> To: general-ide
> Subject: Re: Can't find librcheck.so
Ouch, so basically memory analysis with 6.3.2 is bye bye
Thanks Colin
Well, that's not to say it won't work... :-)
>> -----Original Message-----
>> To: general-ide
> Thanks Colin
> http://community.qnx.com/sf/go/post25610
cburgess@qnx.com
It would be easier to hexedit the librcheck.so and change the DT_NEEDED
to be libc.so.2, or we could just link the patch :)
Ryan Mansfield
Thats is strange. I probably posted wrong version, I suppose to compile it for 6.3.2, let me try again.
And btw you still can use libmalloc_g.so if you really want.
>> frs1427?dl=1
Which platform use libc.so.3? I checked x86 (from the patch)
# ldd ./librcheck.so
./librcheck.so:
        librcheck.so.1 => ./librcheck.so (0xb8200000)
        libc.so.2 => /lib/libc.so.2 (0xb8228000)
Anyway I posted new patch at http://community.qnx.com/sf/frs/do/viewRelease/projects.ide/frs.ide_integration_builds.
called rcheck-632-IDE4_5-02.zip
It is targeting 632 (can work on 640 too) - this also contains some bug fixed.
That link doesn't work for me.
> Sent: March-31-09 10:52 AM
> To: general-ide
> fixed.
> http://community.qnx.com/sf/go/post25667
Post Deleted
Re: RE: Can't find librcheck.so
Another attempt. If it does not work just go to Project Downloads -> IDE integration build and pick patches for
momentics 6.3.2
 http://community.qnx.com/sf/frs/do/viewRelease/projects.ide/frs.ide_integration_builds.momentics_632_patch_for_profiler
