Forum Topic - F3 for Find Next: (4 Items)
F3 for Find Next
I am using the 4.5 Beta and have been unable to figure out the hotkey for Find Next while searching through a source
file.  Momentics doesn't seem to be following the industry standard of using F3 for Find Next.  Is there an alternate
way to do this or can this be added?
Thanks.
AW: F3 for Find Next
that's Ctrl-k
shift-ctrl-L shows you a list of short cuts
/hp
>Von: Bryan Keeney [mailto:community-noreply@qnx.com]
>Gesendet: Dienstag, 23. September 2008 17:19
>An: general-ide
>Betreff: F3 for Find Next
>hotkey for Find Next while searching through a source file.
>of using F3 for Find Next.  Is there an alternate way to do
>Thanks.
>General
>http://community.qnx.com/sf/go/post13869
Geschaeftsfuehrung:  Dr. Wolfgang Ptacek  -  Michael Mauser  -  Regis Baudot
Sitz der Gesellschaft: Karlsbad - Registergericht: Mannheim HRB 361395
Re: AW: F3 for Find Next
Besides that, if you do it for one IDE instance, you can export new
settings and then import them wherever you need.
Hans-Peter Reicher wrote:
> that's Ctrl-k
> /hp
>> An: general-ide
>> Thanks.
>> General
> http://community.qnx.com/sf/go/post13870
Re: F3 for Find Next
This is not a problem:-) You can change key settings using setting tool
Windows->Preferences->General->Keys.
> Thanks.
