09/04/2008 4:51 PM
post12881
I'm trying to use the IDE part of the Alpha release, on Windows. The project is of C++ type. Our makefiles specify gcc3
.3.5 but when trying to build the project from within the IDE I get:
Compiling: shm_pretrait.c
cc: unknown target 'gcc_ntox86+debug+profile'
cc: no targets defined in C:/QNX640/host/win32/x86/etc/qcc/gcc/3.3.5!
The same error comes up for every file. What is the proper course of action to solve this problem, aside switching to 4
.2.4 ;-)
Mario
09/04/2008 5:03 PM
post12882
I'm pretty sure the problem is that your QNX_TARGET/QNX_HOST are pointing to the 6.4.0 versions - there
is no 3.3.5 in the 6.4.0 distribution
gcc3.3.5 but when trying to build the project from within the IDE I get:
4.2.4 ;-)
> Regards,
> Mario
> http://community.qnx.com/sf/go/post12881
cburgess@qnx.com
09/04/2008 5:41 PM
post12887
Anyway to add 3.3.5 and 2.95.3 to 6.4.0, either self hosted or on Windows.
I guess on windows one could install multiple version of the IDE and somehow manage to set QNX_TARGET/QNX_HOST on a per
project basic (that's going to be ugly).
But on self hosted I don't see how I can do it? I mean from self hosted 6.4.0 I *HAVE* to be able to generate the same
executable I build with 6.3.2.
09/05/2008 9:26 AM
post12913
There is no convenient way to do that now. You can copy manually 2.95
and/or 3.35 directories to $(QNX_HOST)/etc/qcc\gcc. However, keep in
mind that it still uses qcc taken from 6.4. Another option is to install
both QNX: 6.3.2 and 6.4, but use only 6.4 IDE (.4.5). Then ]you can
change active configuration using IDE preferences (see QNX page). But to
sort out all the problems you have to update PATH manually to position
correctly $(QNX_HOST)/usr/bin directories and restart IDE. Anyway I
cannot garantee 100% that it works (worked for me in a few cases I
tried it).
Alex
per project basic (that's going to be ugly).
same executable I build with 6.3.2.
> http://community.qnx.com/sf/go/post12887
09/05/2008 9:34 AM
post12914
> tried it).
If he needs to produce identical binaries to 6.3.2, he'd have to use the
both 6.3.2 qnx host and qnx target directories. You won't get
identical binaries if you use 6.3.2 tools and link against 6.4 libraries.
Ryan Mansfield
09/05/2008 9:41 AM
post12916
Oh, definitely! This is what I meant. This is supported by switching in
preferences.
>> tried it).
> Regards,
> Ryan Mansfield
> http://community.qnx.com/sf/go/post12914
09/05/2008 10:54 AM
post12932
> preferences.
> >> tried it).
Don't know if I'm not seeing the big picture but in QNX4 we can compile 20 years old program no sweat, Watcom 9 10 and
11, all living at the same time on a the same system. With Windows and Visual C same story, just have to install the
proper version of Visual C and all is good. It does sound like a major short coming to me. I mean the OS and compiler
should be independent. I should be able to install gcc (2.9.5, 3.3.2?, 3.3.5) and their related libraries in 6.4. I
mean isn't that what qcc -V is for?
The way I see this, in a couple of years everybody here will need to have installed 6.3.2, 6.4, 6.4.2, 6.5 in different
partition and reboot to go from one to the other in order to support the different version of our product.
Maybe there is something I"m missing?
09/05/2008 10:56 AM
post12933
> years old program no sweat, Watcom 9 10 and 11, all living at the same time on
> install the proper version of Visual C and all is good. It does sound like a
> major short coming to me. I mean the OS and compiler should be independent.
> libraries in 6.4. I mean isn't that what qcc -V is for?
> installed 6.3.2, 6.4, 6.4.2, 6.5 in different partition and reboot to go from
Just realized that with 6.3.2 I can't build anything for 6.1 and I've never complained about it. But then again our
first system to be deployed is based on 6.3.2 so the problem never showed up.
09/05/2008 11:29 AM
post12935
It was an explicit decision to make 4.2.x the only compiler available with 6.4. This was a tough one as you have pointed
out - many customers need these other compilers. In the end, we needed to trim the number of branches of GCC we
supported. If we continued on our previous path we would have 2.95.3, 3.3.5 and then 4.2.x to support.
09/05/2008 11:41 AM
post12939
>> preferences.
>>>> tried it).
You can copy 2.95.3, 3.3.5 into 6.4 and switch between them using qcc
-V. But 6.4 will only ship with gcc 4.2.4.
On Linux and Windows host we support coexistence at the SDK level and
you can have 630, 632, 640 all installed beside one another and then
switch back and forth with ease. For self hosted the historical
packaging of the SDK and the runtime together require things to be
manually copied over. We didn't ship a self-hosted SDK package you could
install into 640. I suspect the historical motivation may have been that
self-hosted users would be targeting the same version Neutrino as their
host.
Potentially someone could use the 632 tools to link against 640
libraries by setting QNX_HOST/QNX_TARGET appropriately but your
requirement of being binary identical makes this impossible. The
regardless of which version of qnx host tools you are using, they will
pull from your qnx target directory so while code generated by the 6.3.2
would be identical the libraries it pulls in will have changed between
releases.
Ryan Mansfield
09/05/2008 11:59 AM
post12944
Could QNX make availble 2.95.3 and 3.3.5 as separate archive much like 4.2.1 can be downloaded and installed on 6.3.2.
With ease? Some config depends on environment variable, fiddling around we these is not what I call simple.
> manually copied over. We didn't ship a self-hosted SDK package you could install into 640.
Maybe not go as far as a SDK ( although I believe that is the way it should be done), but maybe come up with some sort
of official procedure.
> host.
Wrong assumption if you ask me, but then again you didn't ask ;-)
Nah nothing impossible (not quite, can't teleport ), impractical or too much work for QNX maybe but not impossible.
> The
> releases.
Needless to say this is going to be a big torn in our collective foot.
> Regards,
> Ryan Mansfield
09/05/2008 1:22 PM
post12955
You mean installed on 6.4? Yes, we have discussed making them available
available on the foundry so this is a possibility. If we did, it
wouldn't happen before 6.4 is released though.
I have them all installed on both my Windows and Linux hosts and
regularly flip between 630, 632 and 640 by changing the
QNX_HOST/QNX_TARGET combo. Putting the env variables in a script could
means you could change environments with one command instead of two. The
environment can also be switched using qconfig utility, and also the
Windows SDK has a utility called qwincfg.
I agree this should be clarified. I would very much like to fully
support coexistence for self hosted. I'm not familiar with inter
workings of the Neutrino installer but I believe the way it shipped
doesn't allow it to be installed under 6.4.
>> host.
To be fair I wasn't here at the time and I am simply guessing as to the
rationale of others. There could be other factors or problems that I am
not aware of that were behind the decision.
No, there's no way to do it. If you want your binaries to be identical
to the ones generated in your 6.3.2 system, you must use the same tools
and link against the same libraries. For example, there were fixes made
to the crt1.o file in 640. By default, every link pulls in this object
file and your resulting binary will be different. To your make binaries
identical, the 6.4 libraries couldn't be changed in any way which means
they would have to be identical to the 6.3.2 libraries. How can things
cannot be the both the same and different?
>> The
>> releases.
I understand. We appreciate the feedback and will take your comments
under consideration.
Ryan Mansfield
09/05/2008 1:41 PM
post12958
We can look at hosting these archives for 2.95.3 and 3.3.5 on the CLT project. This wouldn't necessarily be part of the
official release but something we can provide to support what you're trying to do.
Bill
09/05/2008 1:57 PM
post12962
> This wouldn't necessarily be part of the official release but something we
Yes that would be good enough. Just like 4.2.1 can be downloaded now and run on 6.3.2, I should be able to download 3.3.
5 and run it on 6.4. Then there could be a SDK to install the libraries that came with 6.3.2 (/usr/qnx630, /usr/qnx632,
etc)
> Bill
09/05/2008 1:55 PM
post12960
For us that means we wouldn't use 6.4 for the dev seat till they become available. Note that this doesn't affect our
runtime. The way we build our runtime images is independent of the OS we are build it on.
> >> host.
What I'm saying is I should be able to use the tools that came with 6.3.2 but on 6.4. I should be able to mix and match
SDK/compiler/host at will. Although it would be understandable that some combination would not be officially
supported for example 2.95.3 with the 6.4 libraries.
Thanks for listening.
09/05/2008 1:40 PM
post12957
What I wrote before is the current state. It should be changed before
the final release.
>> preferences.
>>>> tried it).
different partition and reboot to go from one to the other in order to support the different version of our product.
> http://community.qnx.com/sf/go/post12932
