Forum Topic - How can I run my program in the target?: (3 Items)
Hi
  I have a AtmelAT91SAM9263-EK Evaluation Board and the BSP can run in it. Can you tell me  how to run/debug the
application on the target? I have read the document,but it can not help me to do this.   I need a very simple and
detailed sample that can let me know the whole process.  I use QNX Momentics IDE(windows host).  Thany you very much.
the file at91sam9263ek.build list below
## QNX Neutrino 6.x on the Atmel AT91SAM9263-EK Board
## SUPPORTED DEVICES:
## SERIAL:  Atmel DBGU UART
## NETWORK: Atmel AT91SAM9263 EMAC (full stack)
## FLASH:   TBD
## USB:     Atmel OHCI USB Controller
## SPI: Atmel SPI interface
##  - For detailed instructions on the default example configuration for
##    these devices see the "CONFIGURING ON-BOARD SUPPORTED HARDWARE"
##    section below the build script section, or refer to the BSP docs.
##  - Tip: Each sub-section which relates to a particular device is marked
##         with its tag (ex. SERIAL). You can use the search features of
##         your editor to quickly find and add or remove support for
##         these devices.
##  - For details on how build files work, please refer to the help
##    documentation for "mkifs" in the QNX Neutrino "Utilities Reference".
## NOTES:
## START OF BUILD SCRIPT
[image=0x20100000]
[+compress]
#For UBOOT ROM monitor, use raw
[virtual=armle,raw] .bootstrap = {
#For QNX IPL/sendnto, use binary
#[virtual=armle,binary] .bootstrap = {
	startup-at91sam9263ek -vv
        PATH=:/proc/boot:/bin:/usr/bin:/usr/photon/bin LD_LIBRARY_PATH=:/proc/boot:/lib:/usr/lib:/lib/dll PHOTON_PATH=/
usr/photon procnto -v
[+script] .script = {
    procmgr_symlink ../../proc/boot/libc.so.2 /usr/lib/ldqnx.so.2
	display_msg Welcome to QNX Neutrino 6.x on the Atmel AT91SAM9263-EK Board
    ## DBGU SERIAL driver
	devc-seratdbgu -e -F -S -b115200 -c100000000 0xffffee00,1
    waitfor /dev/ser1 4
	reopen /dev/ser1
	slogger &
    ## NETWORK driver
    display_msg Starting on-board ethernet with TCP/IP stack...
    io-net -dat91sam ioport=0xfffbc000,irq=21,rmii,mac=662200021615,verbose -ptcpip -v &
    ## REMOTE_DEBUG (gdb or Momentics)
    ##  - refer to the help documentation for the gdb, qconn and the IDE
    ##    for more information on remote debugging
    ##  - the commands shown require that NETWORK is enabled
    # devc-pty &
    # waitfor /dev/ptyp0 4
    # waitfor /dev/socket 4
    # qconn port=8000
    pipe &
    ## USART SERIAL driver
    #display_msg Starting Serial USART 1 driver ...
	#devc-serusart -e -F -S -u2 -b115200 -c100000000 0xfff8c000^2,7
    #display_msg Starting Serial USART 2 driver ...
	#devc-serusart -e -F -S -u3 -b115200 -c100000000 0xfff90000^2,8
    #display_msg Starting Serial USART 3 driver ...
	#devc-serusart -e -F -S -u4 -b115200 -c100000000 0xfff94000^2,9
Re: How can I run my program in the target?
I guess you are not using IDE. Then see QNX documentation on this topic
( go to the link
http://www.qnx.com/developers/docs/6.3.2/neutrino/building/about.html ).
Alex
xiao wei wrote:
> Hi
> ## FLASH:   TBD
> ##         these devices.
> ## NOTES:
> [image=0x20100000]
> [+compress]
=/usr/photon procnto -v
>      waitfor /dev/ser1 4
> 	reopen /dev/ser1
> 	slogger&
>      ## NETWORK driver
>      io-net -dat91sam ioport=0xfffbc000,irq=21,rmii,mac=662200021615,verbose -ptcpip -v&
>      # devc-pty&
See this user guide Ten Steps to Your First QNX Program, instead of booting target from cd use your own image.
http://www.qnx.com/developers/docs/6.3.2/momentics/quickstart/about.html
> ( go to the link
> Regards,
> Alex
> xiao wei wrote:
>> Hi
>> ## FLASH:   TBD
>> ##         these devices.
>> ## NOTES:
>> [image=0x20100000]
>> [+compress]
PHOTON_PATH=/usr/photon procnto -v
>>      waitfor /dev/ser1 4
>> 	reopen /dev/ser1
>> 	slogger&
>>      ## NETWORK driver
>>      io-net -dat91sam ioport=0xfffbc000,irq=21,rmii,mac=662200021615,verbose -ptcpip...
Attachment: Text elaskavaia.vcf 116 bytes
