Tau crashed (unexpeted error by HotSpot Virtual Machine, SIGSEGV in libxul.so)
07/08/2008 1:35 PM
post10178
Hi All,
Some info about my system:
Host OS: Sabayon 3.5
Host Arch: AMD64
OS Arch: 64-bit
WM : KDE 3.5.x
QNX Momentics: 6.3.2
IDE: 20080516 (latest build to date)
Plugins: QNX Docs plugins (qnx_docs.zip)
When It happens:
I have added the path to qnx docs, and while I open the Help -> Help Contents, a Window opens up with a vertical bar
(frames), trying to contact 127.0.0.1, while populating the contents it crashes.
Error Message:
# An unexpected error has been detected by HotSpot Virtual Machine:
# SIGSEGV (0xb) at pc=0xed640d28, pid=13527, tid=4149610176
# Java VM: Java HotSpot(TM) Client VM (1.5.0_11-b03 mixed mode, sharing)
# Problematic frame:
# C [libxul.so.1+0x420d28]
# An error report file with more information is saved as hs_err_pid13527.log
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
(And the file hs_err_pid13527.log attached)
