Re: Project settings changed
07/02/2008 8:46 AM
post9909
If you are talking about QNX projects, the kind of project (application
vs library) is completely defined by this particular project
sub-directores structure. For example, if project has one of the
following structures:
proj-->nto-->x86-->so or proj-->x86-->so
|-->so-g
|---->so.g
and if this project was identified as a QNX project (see <natures>
section of .project file), IDE recognizes it as a shared object project
targeted to x86 platform having debug and release variants of build.
I tried to play around with project import in IDE 4.0.1 and IDE 4.5
(Tau) and din't get anything like described by you in your earlier
messages. Could it be that you missed there some details of the whole
process? I don't know...
Alex
Tim Gessner wrote:
> I moved some directories around. I created a new workspace and imported the projects. Now one of my projects appears
as an executable rather than a library.
> I am running 4.0.1.
> Is there a simple way to fix this without deleting the project and recreating it?
> Tim
> http://community.qnx.com/sf/go/post9876
