Forum Topic - Can't import existing projects into workspace: (8 Items)
I moved some directories around on my hard drive.  I created a new workspace and tried to import the existing projects
into it.  When I select the folders for the projects Momentics doesn't show any projects to import.
I am running 4.0.1 of the IDE.
Any pointers to figure out this out?
Thanx
Tim
Re: Can't import existing projects into workspace
When you moved your project folders, did you moved the project metadata (.project, .cproject) files? You need to have
those metadata files to be able to import the projects.
Even if you don't have those metadata files, you still can re-use the project data. Create the same new porject, select
the same name and use the existing project folder. You will have to re-configurate your project if you have specific
settings within them.
RE: Can't import existing projects into workspace
Yes, the .project and .cdtproject files are in the new folder locations.
When I browse to those folders to import Momentics doesn't show any
projects there.
Sent: Saturday, June 28, 2008 3:16 AM
To: general-ide
Subject: Re: Can't import existing projects into workspace
(.project, .cproject) files? You need to have those metadata files to be
project data. Create the same new porject, select the same name and use
project if you have specific settings within them.
General
http://community.qnx.com/sf/go/post9816
When I try to create a new project with the same name in the same folder it tells me there already is a project there.
Yet when I try to import that project it doesn't appear in the selection box.
Any help would be very appreciated!!!
Thanx
Tim
It can happened if IDE thinks that it is already has these projects. Did
you move old .metadata directory in your new workspace? (You should not)
If it tells you projects already there can you still press finish to
continue import?
> Thanx
> Tim
> http://community.qnx.com/sf/go/post9874
I did copy the previous .metadata to the new workspace.  After deleting
that I was able to create a new workspace and import the projects.  I of
course had to redo all my preferences.
Thanx!
Tim
Sent: Wednesday, July 02, 2008 6:38 AM
To: general-ide
continue import?
selection box.
> Thanx
> Tim
General
http://community.qnx.com/sf/go/post9916
You can export/import preferences as well.
> Thanx!
> Tim
> From: Elena Laskavaia [mailto:elaskavaia@qnx.com]
> To: general-ide
> continue import?
> selection box.
>> Thanx
>> Tim
>> General
> http://community.qnx.com/sf/go/post9927
Great, I will have to look into that.  Seems that by copying I created
my troubles.  I was only trying to avoid all the preference changes.
Thanx
Tim
Sent: Wednesday, July 02, 2008 7:29 AM
To: general-ide
deleting
of
> Thanx!
> Tim
> To: general-ide
Did
not)
> continue import?
> selection box.
>> Thanx
>> Tim
>> General
General
http://community.qnx.com/sf/go/post9929
