Forum Topic - Expected QNX C++ project file compatibilty between Momentics 4.01 and 4.5? Anyone tried the QNX extensions within Ganymede?: (5 Items)
At the moment I'm using Momentics 4.01 for my QNX projects. But I would like to use the improved C++ indexer of the
newer CDTs. Is it possible to use the same QNX C++ project files within Momentics 4.01 and 4.5? Are there any areas
where I should expect some incompatibility issues?
I would like to stick with the other development tools from Momentics 4.01, e.g. gcc 3.3.5, for the next time.
When I'm already changing my development environment:
May I use Ganymede (to be released today) with the additional QNX features/plugins for 4.5?
Is it reasonable to get and install Ganymede and then use the QNX update site to install the QNX features of the IDE?
Has anybody tried some of the RC of Ganymede with QNX?
Thanks in advance
Christian
Re: Expected QNX C++ project file compatibilty between Momentics 4.01 and 4.5? Anyone tried the QNX extensions within Ganymede?
It depends on which types of project you are  using now. In the latest
build there are still some  problems with regular make project. QNX
project and MBS project types should work well. And I don't think
(admittedly, I didn't try) that 4.5 violates backward compatibility, at
least for QNX project and, for regular make project after its
stabilizing. .
Standard installation of Momentix 6.4 doesn't include compilers other
than 4.2.x. But Ide should work with older Momentics installation  as
well. However, officially we do not support older compilers any more.
I think it shoud work. But it doesn't make a big sense because you
cannot  use CDT 5.0  which was delivered as a part of Ganimede.
> Thanks in advance
> Christian
> http://community.qnx.com/sf/go/post9646
You are interested in CDT 5.0 right? You can install new IDE 4.5 but it
is based on CDT 4.0.3. Since CDT usually does not care much about
backward compatibility using CDT 5.0 with IDE 4.5 won't work because of
API's incompatibilities :(
> Thanks in advance
> Christian
sure. CDT 5.0 has some additional features increasing productivity ;-)
I am aware that CDT 5 is build on the next Eclipse platform (comparing to CDT 4). But you mean that the APIs for the QNX
 IDE tools using parts or hooks in CDT have changed, too? Argh.
In my ideal world I could install and use the newest Eclipse platform with the latest CDT. Afterwards I can install the
QNX IDE tools.
In this ideal world I would be able to open an "old" workspace with the latest IDE and build it using the "old" binutils
/compiler to be able to make bug fixes at minimal risk.
The same IDE would use in "new" workspaces newer binutils/compiler (as selected by the user) ...
Is there a chance to see the QNX specific bits for Eclipse 3.4/CDT 5(Ganymede) in the near future?
You can install IDE 4.5 (exprimental) now and use it with 6.3.2
momentics installation
We do plan to use latest cdt in the future releases.
QNX IDE tools using parts or hooks in CDT have changed, too? Argh.
the QNX IDE tools.
binutils/compiler to be able to make bug fixes at minimal risk.
> http://community.qnx.com/sf/go/post9668
