Forum Topic - How to update qconn?: (9 Items)
i could not realize online debugging the target because of outdated qconn.
I tried to update in this way in the ide 4.0.1:
Help-->Software Updates-->Qconn Updates....
no effects, seemed updated already. and i have copied the qconn binary on my host to the target file system, still the
same. could anyone help? thx
Eric
Re: How to update qconn?
After you have copied the "qconn" binary to your target system, have you restart it (slay qconn; <path>/qconn)?
When you did the "Help-->Software Updates-->Qconn Updates" did you see any pop-up windows telling you that it is already
 updated?
What is release version of your Momentics, host and target? There are three qconn packages bundled in IDE 4.0.1. They
are for three difference releases, 6.3.0SP1, 6.3.0SP2 & SP3, 6.3.2.
BTW, there are qconn enhancements in IDE Tau release. You might want to try upgrade you IDE to the Tau release.
yes, i have restarted.
> -up windows telling you that it is already updated?
No, not any pop up window, no response at all.
> qconn packages bundled in IDE 4.0.1. They are for three difference releases, 6
6.3.2
thx, i will have a try.
> pop
>  6
> 6.3.2
I did but it doesn't seem to update qconn ( where should it be )
Help-->Software Updates-->Qconn Updates won't work in Tau for now.
You need to get patch from foundry and install on host and target (or
re-build image).
>> pop
>>  6
>> 6.3.2
> http://community.qnx.com/sf/go/post11530
> re-build image).
Where would that patch be?
http://community.qnx.com/sf/wiki/do/viewPage/projects.ide/wiki/Builds_Tau_Integration
On this page "Before you install" lists 4 patches recommended to use on 6.3.2 to use new IDE. Qconn is 4th one.
>> re-build image).
> http://community.qnx.com/sf/go/post12043
Attachment: Text elaskavaia.vcf 116 bytes
> >> re-build image).
> > General
i downloaded the qconn patch, put in host and target the corresponding directory. but when i executed "qconn" on 6.3.2
target, it gave me:
  /bin/sh: qconn: cannot execute - Permission denied.
but i logged in as root. what may be the problems? thx
Eric
In your target, do a "chmod o+x qconn". This sets the executable bit.
